Thread: ABS Lights and Traction control lights
    May 2008
    UK
    Default ABS Lights and Traction control lights
    Hi all!
    Looking for a bit of help if possible, I have a Vectra 1.9 CDTI 06 120 bhp.
    While driving yesterday the ABS light and Traction control lights came on, the car still drove fine, but when I tried my wipers whiched wiped very slowly and also electric windows etc. all did same.
    I made it home, switched off the engine and tried to restart it and just got the clicking noise. Now i'm wondering if it is the alternator or battery but if it was the alternator I believe there is a warning light for this??
    I'm gonna get my multimeter out and check the voltage but any help would be greatly appreciated!!
    Thanx!
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    When my alternator went I had no warning light or anything, the car just cut out and then wouldn't start again but like you say could be the battery too especially with the cold weather.
    I had a similar problem on my old car that was caused by the battery, it was low power and ABS, traction control, air bag warnings would happen all the time. i changed the battery and never had a problem again so it could be worth trying another battery on it.
    May 2008
    UK
    Update
    Looks like you were spot on davree. Finally got a chance to look at the car today with the multi meter. Battery had 11 volts in it and after a jump start would not charge. Removed the 6 screws out the battery to find one with bubbles in it. I topped that one up, jump started again and battery is now charging and there is no lights coming on the dash too.
    So a new battery for me once this weather gets a bit better and I can go and pick one up.
    Thanx !!
    Regular Member vockycdti's Avatar
    May 2007
    stoke
    Hi all,
    this has just happened to me the car's revs were slightly high this morning
    thought nothing of it battery light came on but after restart whent off again,just drove the car again after having new tyres fitted , started to park up then all hell broke loose, battery light came on power steering light came on service light came on........does all this point to the battery
    if it does then it would make sense as the car hardly moved for 2 weeks when we had all the cold weather.
    Thanks for any help you can offer.
    May 2007
    stoke
    just a quick update it was the alternator that was unservicable.
  1. ABS & Traction control lights on?
    By keithsimmo in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2013, 20:17
  2. traction control and abs lights on....?
    By jungle in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2010, 21:22
  3. A.b.s/traction control warning lights
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2009, 00:08
  4. a.b.s. traction control lights
    By simplesi in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 11:40
  5. Abs & Traction control lights on
    By iceeee in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2009, 16:17
vectra c abs and traction control lights on
abs light and traction control my vectra c
what causes vauxhall signum abs and traction lights to come on
vauxhall insignia abs light and traction lights on
vauxhall vectra c abs and traction light
