Thread: Factory Fit Alarm
    Darlington
    Default Factory Fit Alarm
    Hi Quick question
    when the alarm goes off do the indicators flash at the same time, just now i thought i heard a car alarm go off? i had a look out the window accross the car park at my Vectra C and didnt see any lights flashing so presumed it wasn't mine, the alarm also only sounded in intervals of say 20 second bursts
    Thanks in Advance
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yes the indicators should flash
    Darlington
    cool so its safe to say it wasnt mine, and i dont have to go out in the rain, its stopped now though
    11 Post(s)
    I'm surprised you heard it, what with the power sounder being in the boot. It's not the noisiest of alarms.
    I take it you've tried deliberately setting it off to see how crap the noise is?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If you disconnect the alarm sounder the car uses the car main horn by default only problem is the warning (Safe) on the display and the fact that you have to cancel it every time and that can be annoying.
    http://www.vectra-c.com/forum/showth...=alarm+sounder
    Darlington
    Hi
    I have heard the alarm going off before as once the car would not unlock using the fob, so i had to unlock the door manually and when I did the alarm went off, but it was VERY quiet, i thought it was very feeble - but i havnt disconnected anything yet to use the horn
    I know i ahould RTFM but im not at home at the moment - if the alarm was to go off, and then was silenced (by itself) how would you know when returning to the car - would the little red light be illuminated on the interior disable switch?
    Ste
    11 Post(s)
    Quote Originally Posted by Redviper View Post
    http://www.vauxhall.co.uk/vaux/owner...do?method=view
    You wouldn't.
    I used to have a META alarm fitted to a Cavalier that flashed up a different LED sequence if the alarm was triggered while you were away from the car. You could tell if the ultrasonics, boot, bonnet, doors or current drain had triggered the alarm.
    Darlington
    Thanks Dave :-)
  1. Factory fit PP swap?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2012, 00:19
  2. Factory amp???
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2012, 12:43
  3. Factory looking DRL
    By lee gsi in forum Styling
    Last Post: 15th September 2011, 21:40
  4. factory fit sat nav
    By jimmi in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2011, 21:37
  5. Factory Bluetooth
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2006, 22:46
