Thread: vinyl wrap
    Regular Member gazza3009's Avatar
    cheshire
    Question vinyl wrap
    hello again are there any people on here who have tried vinyl wrappin in any way. im just about to buy plain matte black vinyl and want to try a diy job as im pretty good when it comes to detail, however this is the first time i will be vinyl wrapping, i know the procedure but have just never done it, is it really that hard to do, need to know asap as im buying it tomorrow. many thankyous, gazza
    Regular Member john-d's Avatar
    Nov 2009
    washington
    best left for pros imo
    WGAF#5
    depends on what your wrapping and the amount of curvature involved - then you ned to get a vinyl suitable for the purpose intended - buy more than you need - if you get it from the states it much cheaper unless you know someone who works in the trade and can give you cut offs or end of rolls to try with first......
    ive exterior vinyled my fog light covers and chrome window strips there fairly straight and "easy" and it still took a couple of hours to do and i may still do them again
    cheshire
    ive found a place which do 5m x 48" for £26.99 and that is made for vehicle wrapping
    WGAF#5
    good luck with the venture - keep us posted - and how about a how2
    Scotland
    I've watched it being done. The guys made it look so easy pretty sure it's not, but I'd love to have a go too.
    Make sure the surface is perfect first, anything on the surface will show through. Use a tack rag to wipe over the surfaces first.
    It's also fitted dry, they did use water. They used a hot air gun to put some heat into it for the more curved areas, and simply pulled it and stretched it squeesing out the air bubbles as they went
    Where did you see the sheets for buying?
    cheshire
    The website is mdpsupplies.co.uk and I need to correct myself it's actually 13.95 for a 48"x5m roll
    Scotland
    Cheers.
    I've actually used them before for graphics vinyl, good stuff.
    Regular Member *AJ*'s Avatar
    Nottingham
    Ive seen pro's mess it up, so good luck.
  1. vinyl wrap full car
    By 0114NIGEL0114 in forum Bodywork & Interior
    Last Post: 4th December 2012, 01:19
  2. vinyl wrap trim
    By v6signum in forum Styling
    Last Post: 10th September 2012, 23:18
  3. Vinyl Wrap
    By 19CDTi in forum Styling
    Last Post: 18th June 2012, 12:41
  4. Replies: 13
    Last Post: 17th November 2011, 21:45
  5. vinyl wrap
    By simplesi in forum Styling
    Last Post: 24th March 2011, 22:04
