Thread: reset service indicator
    staffordshire
    Default reset service indicator
    can the service indicator by reset without access to equiment 05 plate vec 2.0 turbo. If so how 2 pls
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    with ignition off hold in the trip reset on dash and turn on the ignition hold till you see it reset them off and on again with the ignition
    Full Member spennny's Avatar
    Blantyre
    - With the ignition switched off, press and hold in the odometer button;
    - Whilst holding in the odometer button, press and hold the brake pedal;
    - Now, continuing to hold the button and the pedal, switch on the ignition;
    - Hold down the button and pedal until the "INSP" light stops flashing and turns to 3 dashes "---"; and
    - Switch off the ignition
    nottingham
    Trim : 2.0T Design
    Engine : Z20NET
    Mileage : 43000
    will that work for an 05 plate cdti??
    Mileage : 55000
    Should do. I would have thought. But if you have it service by VX I would leave it to them. Me I do my own, so I switch it off myself when I service my motor.
    nottingham
    Trim : 2.0T Design
    Engine : Z20NET
    Mileage : 43000
    service it myself mate and had heard you could not reset it!!
    will try tomorrow ta
    Mileage : 55000
    Quote Originally Posted by stiggy View Post
    On some models you need to press the footbrake too.
    Bedford
    holding down trip button, and brake pedal then switching on the ignition cleared the service indicator on my 56 plate 2.2i direct petrol
    Regular Member congaman's Avatar
    Sep 2010
    UK
    Thanks For this information! I have just reset my service light after doing a air filter change. 2.2 DTI
    Thanks!
    I now need to do the oil and filter
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Never needed to touch the brake pedal on either of mine. Hold in the trip meter button for 20 odd seconds, the display changes and service light gone.
  1. 'Service Due' Indicator reset question
    By wafoo in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 00:38
  2. Service Light Reset
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2008, 18:19
  3. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
  4. how to reset the inspection indicator
    By aerodynamic18 in forum Troubleshooting
    Last Post: 6th September 2007, 22:59
  5. Service Light Reset???????
    By rob CDTI in forum Troubleshooting
    Last Post: 22nd May 2006, 22:25
