Results 1 to 10 of 16
Thread: ABS light wont go off.
    Jul 2009
    The Rift, Cardiff
    Default ABS light wont go off.
    As title, started the vec today and the car and spanner pic came up and the abs light in the centre (between speedo and rev) came on and stayed on. I turned car off and started again abs light stayed on!
    Any ideas what could be causing this?
    Cheers, bil
    Jul 2009
    The Rift, Cardiff
    Just been out to do the How2 read fault codes, it came up with
    1614
    1616
    0170
    0100
    1405
    1565
    1525
    1550
    What do they mean? The lists of codes have a letter (b, c, p, u) before the codes, how do I tell which one it is?
    Any help would be much appricated.
    Bil
    Jul 2009
    The Rift, Cardiff
    Anyone got any ideas? Not keen on driving with out ABS.
    I did notice a loose wire hanging behind the front passenger side brake, but I tink thats the pad wear sensor (there's no wiring on driver side?)
    Jul 2009
    The Rift, Cardiff
    Bump
    Jul 2009
    The Rift, Cardiff
    Anyone? I've tried search but it omits ABS!
    Jul 2009
    The Rift, Cardiff
    Bump
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Default re ABS
    hi
    the only two things come to my mind is
    1. ABS unit is gone
    2. One of your abs sensors ( choice of four ) wire or sensor itself is damaged. I had split wire at the front and you have to change whole hub I'm afraid
    If you did notice that loose wire the cheapest option will be changing front pads or replace the pad wear sensor ( they have droped them on facelift) and then see what happenes
    HTH
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    B codes are body
    C codes are chassis
    p codes are engine
    u codes are canbus errors,
    which ones are the c codes u had?
    Jul 2009
    The Rift, Cardiff
    Thanks for replys,
    Quote Originally Posted by Sebastian View Post
    ...1. ABS unit is gone
    2. One of your abs sensors ( choice of four )...
    How can I identify if its the main unit or which wheel?
    Quote Originally Posted by plasma View Post
    B codes are body
    C codes are chassis
    p codes are engine
    Thats the problem i've got. I used the flashing engin light method to get the codes and when I looked them up they've got those letters. How do I know if the fault is b c p or u?
    Cheers Bil
    Jul 2009
    The Rift, Cardiff
    Update; popped her up on axle stands yesterday, checked and cleaned the connectors. Today the abs light has gone out. Hope it stayes out now.
  1. spanner light and wont idle
    By wbm156 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2011, 16:26
  2. why wont spanner light go off
    By japeye86 in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2010, 22:23
  3. 2.2petrol wont rev/oil level light on/etc HELP!
    By alan ramsay in forum Engine & Drivetrain
    Last Post: 1st August 2010, 18:58
  4. boot open light wont go out
    By walker in forum General Chat
    Last Post: 12th February 2009, 21:16
  5. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
abs light wont go off vectra c
