Results 1 to 10 of 11
Thread: front fog light question??
    Regular Member bish's Avatar
    peterborough cambs :P
    Eek front fog light question??
    has anybody fitted front fog lights to there car that didnt have them??? my loom has the plugs on them, brought a different headlight switch that has the front fogs on them, just put the new switch in, but they dont work lol...and now when i turn it to sidelights they dont work, only when i put dipped on, and before i could have my lights on, turn the ignition off and take the key out, and would get a warning that they are left on, but now they just go off straight away arghhhhh
    Cambridgeshire
    Not sure mate. Maybe they need to be programed by the tech2 at Vauxhall bud?
    Leicester
    They will need programming with Tech 2.
    well after spending ages looking through old threads in the search bit, looks like im going to have to retro fit them, as a few people mention the ls ecu is different
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    a work fitted them for a plod. he had to buy a new uec (engine fusebox) as when i went to program with tech 2 said unavalable.
    Leicester
    You have more chance of the car having the right ECU's on original half canbus pre-facelift cars.
    Feb 2007
    North west
    Still if i retro fitted them just for the appearance I would want them to work. I retro fitted them to my vec C and just did my own wiring IIRC - just ran a relay to the switch. I took the feed for the relay from the side light circuit and everythin worked fine. It was a 52 plate if that helps regarding Canbus / part Canbus - im not sure what it was. I did wire up a second rear fog on both the Vectra and my 07 Astra and that caused no canbus issues on either car.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Cant you just install your own direct feed from the battery, and an aftermarket switch/fuses... but use the standard fogs. surely that wont cause problems?
    Quote Originally Posted by leemarksmith View Post
    yeah thats what im going to do, theres a few fog lamp wiring kits on ebay, just that i brought a new switch with the front fogs, and would of liked to use that, but will just put a rocker switch some where inside
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Quote Originally Posted by bish View Post
    Take the back off the switches... i'm sure you may be able to work out which to solder your own wiring kit to, be worth a go...
  1. Front fog question.
    By stuk2000 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2013, 19:45
  2. Fog light question
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 22:26
  3. fog light question
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2012, 22:33
  4. Fog light question
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2009, 23:59
  5. front fog light question
    By j1 wyx in forum General Chat
    Last Post: 5th October 2009, 18:52
vectra c fog light loom
insignia fog light programing
