Thread: Winter tyre pressure
    Sep 2009
    Glasgow
    Default Winter tyre pressure
    Hate the snow now, got stuck in the carpark at work this morning for 30 min had to phone out some of the boys to give me a push just to get parked, same tonight about 20 min to get out, mind you think the shopping center dosn't know how to use grit as none has been used since all the snow started, after 4 days off work over christmas the car park is like a sheet of ice. Anyway normally run tyres at 36 psi all round should i keep them at this or are there recomended tyre pressures for winter driving.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Here are the standard VX recommended pressures
    Engine
    Z 19 DTL,
    Z 19 DTH
    215/55 R 16,
    215/50 R 17,
    225/45 R 17,
    225/45 R 18,
    Tyre pressure for
    load of up to
    3 people
    Front 33/2.3 Rear 33/2.3
    Tyre pressure (ECO
    1) loaded w ith
    up to 3 people
    Front 38/2.6 Rear 38/2.6
    Note 1) To reduce fuel consumption as much as possible
    I've got mine set to 34 all round 225/45/18
    Mar 2007
    Tamworth
    Have a look in the owners manual for the recommended tyre pressures for your model and tyre size.
    I've never been aware of a manufacturer recommending different pressures for cold, or hot, climates.
    The cold weather does reduce the pressure naturally so you need to regularly check/adjust the pressure to whatever Vauxhall recommend.
    Regular Member mcints77's Avatar
    Jul 2009
    Tomintoul- Scotland
    Vehicle : SRI 1.9 CDTI 120
    Trim : SRI
    Mileage : 62000
    Why bother if u need a cheap short term fix why not buy a set of these their is video on youtube of them working on cars in the snow.
    OH yeah THIS is what i was on about.
    Sep 2009
    Glasgow
    found this I run mine at 35 all round
    http://www.michelin.co.uk/michelinuk...006121126.html
    I check my tyre pressures weekly, and they do vary slightly with temperature
    I also try and check them around the same time (21:00 to 23:00)
    However, even at this time of year the variation in daily temperature is minimal
    At the moment the typical day temperature is about -5'C and it is not likely to return to 15'C until at least March
    According to my handbook (for 2004MY)
    Z19 engines have the same tyre pressures front and rear, anything between 32 and 35
    As far as I am aware none of the UK specification cars have 15" wheels, so that leaves just 32 and 33
    I assume 32 is for the 120 and 33 for the 150
    Leicester
    There is not pressure change for cold weather according to VX specifications.
    M8Internet is right, 15" wheels were never offered in the UK.
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Is it wintertyres? M+S? Then, definately you should add more pressure during cold season. But also on summertyres you can add some. Most car brands only specify "summer pressure", and this is much to low for the below freezing temps. You can add 20%, and only get benefits. It will NOT wear the tyre. When temp again is constantly above 5-10°C, consider only 10% more than standard. Remember to measure when tyres are cold, they gets lukewarm pretty fast...
    Bent, my name is Bent
    Mods: I polished it in september...
  1. winter tyre sizes.
    By Chuff in forum Handling & Braking
    Last Post: 29th September 2011, 10:42
  2. Winter tyre warning
    By Derek Mc in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2010, 16:08
  3. Winter tyre sizes
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2010, 15:01
  4. winter tyre prices are up
    By SigSco in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 14:07
  5. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
