Results 1 to 10 of 11
Thread: Which engine is in the 2003 Astra Sri Turbo?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Default Which engine is in the 2003 Astra Sri Turbo?
    Same as the Vectra and Signum 2 Litre or the older engine?
    Sweden
    The older one .... Z20LET
    'Norf Yorks.
    Thanks is this the Saab engine basically?
    Quote Originally Posted by CDTi
    Someone's thinking about BSR aren't they?
    Regular Member signumT's Avatar
    grimsby
    if im right in thinking the signum has the z20net lower compression
    [Ex]Admin Duncan's Avatar
    Yep, the 2.0T in the Vec C and Signum is the Z20 NET. The Astra that CDTi refers to will have the Z20 LET.
    If he's thinking of tuning that engine then there's a massive choice out there for the Z20 LET- unlike the Z20 NET!
    Leicester
    The Astra SRi Turbo has an early version of the Z20LET which runs 3201 software, this is also shared with the Coupe. 189bhp (192PS) an 185lb/ft. Still gave the car a 0-60 time of 7.0 seconds dead.
    The first upgrade on these is to install 3202 Astra GSi software, this although gives better figures 197bhp (200PS) and 185 lb/ft, it is a much better map making the car drive much better
    Any info you need John on this engine, then let me know, after owning the Zaffy, I have got to know alot of what can be done
    'Norf Yorks.
    Cheers Matt will be calling ya later mate
    Forgot the same engine as the Zaffy!
    'Norf Yorks.
    No not BSR mate
    If I do what I think I would do it properly
    Leicester
    The Z20 LET is still going strong in the Astra H, but it is called :-
    Z20LEL (170PS)
    Z20LER (200PS)
    But all the mechanicals are identical for the above and the Z20LET.
  1. Replies: 4
    Last Post: 18th August 2017, 06:54
  2. 2003 1.8 sri, which engine oil?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 22:17
  3. astra let engine turbo wanted
    By happypostie in forum Engine & Drivetrain
    Last Post: 6th October 2010, 20:49
  4. I found the best price for a new turbo 3.0 V6 cdti 2003
    By littlejohn in forum Engine & Drivetrain
    Last Post: 5th March 2010, 08:48
  5. 2003 Astra Sri Turbo F/S Ex Damaged (Update)
    By Mark2.2 in forum Cars for sale
    Last Post: 27th June 2006, 13:29
