Thread: LED Relays
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Default LED Relays
    I've been looking into solving the problems with my LED indicators flashing when off & the problem with using LED's as sidelights. While doing this i chanced on some sellers offering LED relays which claim to correct the unwanted flashing.
    If they are any good they'd be preferable to fitting a total of 14 load resistors for the indicators, side, rear & reversing lights.
    Has anyone had experience of these & if so, what are your findings?
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    the ones that say canbus compatible still flash... pain i know but think most people stick with bulbs or put up with it...
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    I'm not so much talking about the LED bulbs, i already have them, what i'm enquiring about is a replacement relay for the indicators which is suitable for use with LEDs, in turn stopping the flashing when they're not in use.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Regular Member bridgel's Avatar
    Jan 2010
    st helens
    i have the same problem... i did try jery-riging a standard relay between the light cabling and the lights... but when it started snowing i gave up and went for a cup o tea.....
    wud be good to see if thers a cheap and cheerfull solution...
    Jan 2010
    st helens
    right ok, i finally finished my relays (in the cold) and works a treat...
    if any 1 wants the diagram i can provide... will take pics when its tidyed up and warmed up
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    i for 1 would be very interested in seeing what youve done, preferable to all the load resistors youd have to fit.
    the ones i was talking about actually replace the various relays for the lights. different ones have different pin configurations i guess for different applications. the prices seem to be around the £15 mark plus postage & come from Hong Kong.
    Jan 2010
    st helens
    Hi Kentish,
    its not nearly as complicated the way i have done it (mainly because i'm not a big fan of working out resister loads n such,
    i'l sort a diagram and when i have completed all the relays for the rest of my lights i'l post some pics
    Jan 2010
    st helens
    diagram....
    as you can see its not the most complicated or tidyest thing in the world...but works for me hope it hepls you.
  1. Relays
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2010, 13:23
  2. info on fuse and relays?
    By hoochydady in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2010, 20:51
  3. how many abs relays does vectra c sri
    By abbo88 in forum Engine & Drivetrain
    Last Post: 15th November 2009, 18:40
  4. Relays under bonnet
    By blue estate in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2008, 08:32
  5. How to do so much with relays and more
    By chrisgettings in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2006, 13:13
vauxhall vectra c led relay
