Thread: Temperature gauge failure / spanner light
    Warrington
    Default Temperature gauge failure / spanner light
    Hi Guys,
    Driving to work today and the spanner light flashed up a few times whilst i was driving but had no major effect to the engines performance. I then got to work turned the car off and then back on again and the spanner light came up again just after ignition. Whilst then driving back home it flashed again whilst i was driving but i also noticed that the engine temperature gauge had not moved at all and this is a 15-20 minute drive. Can someone advise whether it is just a sensor that has gone and what i would be looking at it to repair it?
    Thanks in advance
    Check the coolant gravity
    If there is not enough coolant ratio, the coolant system may be partially frozen (along with other internal damage)
    If the gravity is sufficient then the thermostat may have failed
    What has the outside temperature been like in your area?
    Where I am it has been between -15 and -3'C for the last 72 hours now
    My engine takes about 30 minutes to warm up and even then it is only getting to about 80'C
    Warrington
    The temperatures haven't been too bad it has been about 3 degrees today and the past couple have ranged from 0 - 2 degrees. It is reading the temperature in the cd/display unit just the engine temperature gauge seems to have failed along with the spanner symbol flashing on. Is it an easy part to possibly fix?
    London/Essex
    According to the owners handbook that spanner light means the fuel filter needs draining (unless it's an auto in which case it's a gearbox fault). Easy job, little screw on the underside of the fuel filter to drain of any excess water. Might be just as well to change the fuel filter itself.
    Warrington
    Would this make the temperature gauge not to work?
    London/Essex
    Who knows ...
    As far as I'm aware the spanner light and the temperature gauge are unrelated, you seem to have to faults.
    Oct 2009
    fife
    Default temp sensor or thermostat
    would i not be correct in saying that it is more likley the engine temp sensor is failing as opposed to the thermostat as there is no mention in original post relating to cold heaters etc.i may be wrong so please accept my appologies if so.
    regards 9tjc
    Warrington
    The heaters are fine 9tjc so you would be right, it looks like the engine sensor has gone. Going to get it looked at this week so hopefully find out what has happened!
    dublin
    Quote Originally Posted by Scarface08 View Post
    I have the same problem..I changed the sensor(it's a piece of cake..) but to no effect. The fault code from the is p0115-temp. sensor or wiring fault..I hope that the new sensor is faulty too cos with the wiring is like entering into the jungle..
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Hi, did you resolve your issue?
  1. temperature gauge
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 15:20
  2. Temperature gauge
    By ziggy1 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2012, 02:35
  3. Spanner Light and Temperature Gage
    By Princess D in forum Vectra C / Signum Troubleshooting
    Last Post: 27th September 2010, 13:37
  4. Temperature Gauge Help
    By Oscar Ding Ding in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2007, 21:51
