Thread: HID's
    Regular Member ahaz123's Avatar
    Oct 2009
    N. Ireland
    Default HID's
    i know there are tons of threads on here about hid's... but i couldnt find what i was looking for.
    i have hid's in my dipped beam (h7's) and im wondering if anybody has put them in their full beams? and also their foglights?
    i need to know what bulb size to get for the full beam (ie h3/h1 or whatever)
    for the foglights i was wondering.. im on my second set of hids for my dipped beam as the first set didnt always turn on first time (faulty wiring) and i read somewhere that someone had put their old h7 hids into the foglights? does this work/is it a direct fit?
    cheers for any help guys
    11 Post(s)
    H3 for your fogs.
    HIDs in your high beam will be a waste of time because of the delay in them lighting up. How will you be able to flash someone out of a junction or warn someone of your presence if you're waiting for the main beams to come alive?
    Quote Originally Posted by ahaz123 View Post
    Oh it works - I just had to strip with plug off the end and attach the fog light plug instead. They all work off 12V so there's no issues, and the cancellors stop the bulb warning. I've got the VXR fogs which take a completely different design of bulb (have got a right angle and weatherseal on them...) so I just trimmed the back of the foglight and araldyted the bulb in place to both attach and seal it...
    Sorted...
    As for the main beam - even cars with factory fit xenons have a normal bulb for main beam. If the car has Bi-Xenon (like the vectra) then it simply opens a shutter in front of the xenon bulb where it would normally cover half the bulb. It also puts on the normal bulb at the same time. This is a legal requirement.
    Oct 2009
    N. Ireland
    ahh i see, so you think it would be a better idea to use my old h7's for the foglights instead of getting an hid h3 kit??
    Only needs a bit of modding to make the connections work and saves 70 squid on a new kit, so yeah it's definitely worth a try...
    Oct 2009
    N. Ireland
    sweet man, i just took out one of the fogs there now and it seems easy enough to fit, may just need a bit of bending and thats about it!
    cheers
  1. HID's
    By disco dan in forum Styling
    Last Post: 11th June 2011, 23:59
  2. hid's
    By G4GAV in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2011, 18:42
  3. best HID's
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2010, 10:16
  4. HID's
    By Daywalker in forum Styling
    Last Post: 15th November 2009, 18:20
  5. HID's
    By david.91.09 in forum Styling
    Last Post: 24th October 2009, 18:28
