Thread: ffreeezzzing part 2 (water in boot wheel well)
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Default ffreeezzzing part 2 (water in boot wheel well)
    hi there muckers
    this is the second part about frost on inside the windows,what i have found is that there is water in the spare wheel well, about half inch.
    so i am really asking everyone if they can help as this is get on me nerves now coz the weather wont let me get to find the leak.
    this is wot ive found so far
    water in wheel well
    water on the inside of the rear compartments behind light clusters.
    water on the inside of the rear wings
    the carpet is dry though and the rear parcel shelf
    the only thing that i have noticed that is faulty is the ariel on the roof the seal has perished would that allow water to run through the body.
    the boot seal looks good.
    could it be from the rear light clusters
    now i am persuming it is coming from above but could be coming from the road but aint had the chance to look yet (fricken weather)
    any help would be fantastic
    cheers all
    mark
    Mar 2007
    North East
    Check the gutters on the roof.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Does the boot shut tight, with it shut, does it have some movement if you lean on it..?
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by rockh View Post
    hmm not tried that but wot wud that do mucka if it was blocked then there wouldnt be any water at all would there???
    and if they was clear then the problem lies somewhere else, or am i missing the point
    thanks for your advice it is much appreciated
    Nottinghamshire
    Do a seach using the button at the top of the page - there's loads on here about what could cause the boot to leak and how to fix them all.
    Nov 2009
    south wales,Cwmbran
    that seems fine muck
    Regular Member li4m's Avatar
    west midlands
    i had a rover 200 with water in the wheel well once i dried it out it was fine no idea how it got there. check the lights arnt leaking but it seems strange that all the carpet is dry if the wheel well is wet
    hull
    had this with the cav mate. had to dry it out, shut the boot romoving carpet in the boot, lower back seats and have someone spray a hose over the car while your inside seeing where the water is getting in.
    mine was a seal around the tailgate.
    seems alot of trouble but the only way
    Nov 2009
    south wales,Cwmbran
    just searched it and suprised how many ppl had same problem i just hope it is the most common one in the thread which is the gutter rails
    cheers james24 for the reply
    Full Member paul.sessions's Avatar
    leighton buzzard
    will check my gutter rails and my boot has loads of play in it dan when it is shut.. will have to look into tightening it up cheers my elite
  1. water in boot
    By andy bo in forum Bodywork & Interior
    Last Post: 13th January 2016, 23:47
  2. What cured your water leak (hatchback, damp floor in boot/spare wheel well)
    By DNS in forum Vectra C / Signum Troubleshooting
    Last Post: 5th October 2011, 19:31
  3. Water in Boot
    By bigmac in forum Bodywork & Interior
    Last Post: 9th April 2009, 20:12
  4. Water in the BOOT!!
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2007, 09:06
