Thread: Help, my Heater Has stopped working
    Default Help, my Heater Has stopped working
    Hi you guys,
    I have a Vectra 02 2.2 elite. Loving Female owner.
    A bit of a long story but you will need to see full picture.
    On Boxing day, cleared snow etc from car, washed windscreen with cool water to get rid of ice, lots of ice. Put on heater all working ok, then all of a sudden it started to struggle and just cut out. It has not worked since.
    I have looked on sites for answers but not sure what to look out for.
    Called out auto electrician who is unsure himself and had a code of B3916??
    Really need the car to work, pretty broke at the moment. Have read it can be resistor or motor, any suggestions where to take it to instead of vauxhall directly. Can I fix it????????I live in Manchester.
    Mileage : 000
    Snow might have blocked the drain holes by the pollen filter, and water might have then got onto the resistor pack. it is situated on the side of the motor. I belive you can buy the resistor pack from VX, a good mechanic should be able to repair it for you.
    Have a look at this thread, it might be of help.
    http://www.vectra-c.com/forum/showth...eater+resistor
    http://www.vectra-c.com/forum/showth...hlight=heaters
    WGAF#5
    hi sorry to hear of your predicament
    B3916 NO communication with alarm siren
    (0r) not present= so not related to your heater issue
    have you checked the fuses - i know its a silly thing to ask but if it was sounding like it was struggling more likely to have blown a fuse or burnt out
    Thankyou for your advice. Fuses were checked but they seem fine. If it is the resistor, is it something I could fix? Or am I best taking to a garage?
    wigan
    hi nessie just replaced my resistor took all off 30 mins quite easy my heater only work on speed 4. 1 2 3 not work unscrew your glove box 5 screws behind it u will see fan motor the resistor is at the bottom right hand side u will see a white clip with wires comin out of it push it to the right then it will fall out unclip old resistor n replace with new one then slide it back hey presto mine worked 1 2 3 4 warmth again cost £28 pound saved a fortune.
    Sep 2009
    Swindon
    Or just replace the therma fuse on the resistor pack from Maplin for 79 pence.
    Regular Member Mark0's Avatar
    Scotland
    I did this just recently. Think I'll do a 'How To....' guide for it as a lot of people seem to have the problem.
    slough
    hi guy`s hippo here i had this problem on about 8 of these vectra c`s 1,2,3, fan speed dont work but 4 does. remove glove box look up at the left hand side under the dash there is a blue relay change it i think you will be plesently suprised.......
    Oct 2009
    newport
    hopefully its the resistor pack and not the climate control module that failed in mine last week! good luck!
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    i dont knwo if elites have the same resistor pack as normal aircon? think i saw someone mention it was different?
  1. heater motor has stopped.
    By Jen in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2010, 20:23
  2. Heater stopped working on my Vecra 52reg
    By coxstevuk1973 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th January 2010, 21:16
  3. Heater blower stopped working
    By owb82 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2009, 18:24
  4. heater stopped working
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 07:56
  5. Heater blower has stopped working
    By Dave1971 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2008, 12:55
