Results 1 to 10 of 14
Thread: fuel pressure problem
    Sevenoaks
    Default fuel pressure problem
    Hi,
    New to this forum, just bought an auto 05 vectra 2.2 direct design and it's immediately had problems when the engine is under strain, ie. trying to accelerate up a steep hill etc. or just fast acceleration in general. If pushed too hard the car ends up needing to be stopped and restarted.
    I took it to a local garage and the fault code came up with something to do with the fuel rail pressure fault, I think and I'm not 100% on this but the error was "P0191 Fuel Rail Pressure Sensor Circuit Range/Performance". The suggested areas were wiring, fuel pump and ECM. They suggested changing the fuel filter/fuel pump but they are really busy there and said it would take time to sort this out, which could cost big money.
    Just wondered if any of you seasoned owners/mechanics have had similar problems and could give any advice?
    Cheers!
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Quote Originally Posted by officerbel View Post
    Hi,
    Cheers!
    Similar problems that a lot of 2.2 petrol owners are having. I had similar problems to you and it was the high pressure pump - @ £552 to fix. But it could also be some thing else, less expensive.
    Sevenoaks
    Cheers for the reply KC, I have looked the issue up and it seems this is the obvious problem, ie. replace high pressure pump.
    My question is, is it better to go to a vauxhall garage to get it fixed, or go with a cheaper garage which (may?!?!) be able to get and fit the part? (If this is a newbie/silly question, sorry guys, am pretty new to this!)
    I have to say its rather frustrating having to drive the car so "conservatively" if you will (ie. moterways up a hill I KNOW I can only budge it up the hill at 2-3000 revs at 60-65mph!), if I wanted to drive as such, I wouldn't have got a 2.2l car in the first place!!!
    London/Essex
    ... is it better to go to a vauxhall garage to get it fixed, or go with a cheaper garage
    Who knows for sure, you pays the money ...
    Personally any Main Stealer would have to be a complete last resort for me, you and others on here may feel different.
    Best advise I can give is to ask around locally and take it to a recommended reputable local garage. In my experience the locals tend to try harder, their more hungry for your business.
    Jun 2006
    Kirkintilloch, Scotland
    Replacing the fuel pump is an incredibly simple DIY job.
    Check out this thread.
    Dave
    Quote Originally Posted by DaveG View Post
    Dave
    What thread?
    Sevenoaks
    I take it this is the part I need?
    http://cgi.ebay.co.uk/Vauxhall-Fuel-...item2eaa00abdd
    Seemed about the going rate for these? Is it worth me trying to get a used one from a breakers yard, to save some cash, or is it better to just go for the £300ish new cost, it seemed reasonable enough anyway at that price?
    Hopefully this will solve the problem with the car anyhow!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    You need to make sure that your new pump is the new revised pump or you could end up replacing the same part again. At least get the proper info from VX so you know what your buying.
    Sevenoaks
    How do you know if its the new revised one?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I'd imagine there would be a different part number. There's plenty of info on the subject in the forum, it just might take a while separating the wheat from the chaff. Use the Search function at the top of the forum mate, but as I say its going to take a lot of reading to find the part number. Your dealer should be able to give you the new part number mate.
  1. Help!! Dreaded fuel pressure problem
    By piriemr in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2012, 20:41
  2. Anyone with a Z22YH .. NOT had the Fuel Pressure problem?
    By ShamusUK in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 14:30
  3. Insignia low fuel pressure - common problem
    By graded-appliances in forum Insignia car chat
    Last Post: 1st June 2010, 13:14
  4. Tonight on BBC's Watchdog - Vauxhall fuel pressure regulator problem
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2009, 18:53
  5. H.p fuel pump pressure regulator problem 2.2 direct
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 18:06
changing the high pressure pump vectra 2.2
vectra low fuel pressure 0191
how to remove high pressure pump vectra c 2.2 site:www.vectra-c.com
vectra c fuel pressure sensor
opel vectra a fuel pressure
astra 2.2 litre low fuel pressure
vauxhall vectra 06 fuel pressure sensor
z22se faulty pressure regulator
p0191 opel z22yh
vauxhall insignia low fuel pressure
how to change the high pressure pump on a vectra
vectra c fuel pressure problem
p0191 fault code vectra c
vectra 2.2 direct po191
zafira 2.2 fuel pressure regulator price
fuel pressure pump vectra z22se
