Thread: More CDTI 150 woes!
    Birmingham
    Default More CDTI 150 woes!
    Hey chaps,
    Another one for you with regards to the CDTI 150.
    Basically, it stinks, not inside but outside. Yesterday we left it running to warm it up as it was freezing, and when I got back outside, there was a VERY VERY strong smell from it, almost like when you are behind a motor giving it some boot and you can smell the CAT. But this was more Diesel fumes!
    Now I know I have a suspected EGR fault which I am doing on a WIP, but what on earth could be generating such torrid fumes?
    Ocassionally you can smell it inside when the cars moving, but that was only one complaint once?
    Anyone?
    Bye bye Vec B
    - Hello Siggy!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Injector seals..?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    i had that and the leak off pipes done cos they were weeping
    Birmingham
    Is that the little pipes off the Injectors? The rubber braided type ones?
    Bye bye Vec B
    - Hello Siggy!
    Are you VXR Enough
    13 Post(s)
    thats them
    Birmingham
    So you had the terrible smell too?
    Im getting the wobble on idle too, since your comment im starting to wonder if this has something to do with it?
    Bye bye Vec B
    - Hello Siggy!
    Are you VXR Enough
    13 Post(s)
    the idle wobble that could be a duff injector or the 3rd injector wiring plug or a no of things bud
    Birmingham
    3rd inj wiring done already mate. I suspect Injector?
    Bye bye Vec B
    - Hello Siggy!
    Are you VXR Enough
    13 Post(s)
    could be bud
    Oct 2009
    Teesside
    Wobbling on idle could be your DMF, any rattling when you have bring your clutch up slowly?
  1. CDTi Sri woes
    By SeeDeeTeeAye in forum Engine & Drivetrain
    Last Post: 6th January 2013, 21:29
  2. Replies: 10
    Last Post: 1st June 2011, 14:43
  3. V6 CDTI SCV woes
    By averdigi in forum Engine & Drivetrain
    Last Post: 28th March 2011, 20:30
  4. 150 CDTi woes
    By Cannop in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 16:42
  5. air con woes
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2008, 19:23
