Thread: control unit steering column module fuse burning out !!! Please help
    Jul 2009
    San Jose
    Default control unit steering column module fuse burning out !!! Please help
    Hi,
    I have an Opel Vectra C 2004, engine Z22SE and I have a problem with the control unit steering column module fuse. It is burning everytime I try to start the car. I already replaced the fuse but the problem still occurs. I need some help, maybe if someone can give me the electrical diagram of the car or if someone knows hot to fix it will be great. I think the problem maybe is a cut wire touching the chassis but for looking on this I need the electric diagram
    thanks for the help in advanced.
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Does this help ?
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    I would look at the two black ignition live (output wires).
    These are the only two that change when you try to fire up (switch on the ignition barrel)
    They should both go to the underhood (engine bay) fuse board.
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Did you find the cause of your fuse blowing issues?
  1. Column Interface Module
    By dkpcrox in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2013, 03:12
  2. Steering Control Module
    By chrisd in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2008, 23:47
  3. Steering wheel Control Module Question...
    By Penfold101 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2008, 00:35
  4. Steering Column Control Unit
    By pauldizz in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2008, 10:22
  5. Steering Control Module
    By spoons in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2008, 21:50
vectra c steering column module
location of steering control module on 2008 vauxhall vectra
vauxhall zafira steering column module
chips steering column moduul vectra c
vauxhall steering control module
