Results 1 to 10 of 16
Thread: outside temperature display just says F, any ideas ?
    walsall west midlands
    confused outside temperature display just says F, any ideas ?
    hiya guys,
    i have had this problem for a while now but it has started to annoy me.
    earlyer this year the outside temperature sensor just decided to display "F" on the display.
    staight away i thought it would be the sensor had gone faulty,,so i bought a new one from vauxhall and changed it,,,alas the fault was still there.
    after the car has been sitting for some time when the door is unlocked it will show --.-oC then go off (i presume this is resetting itself) and then F will show on the display.
    please help,,it is anoying me now !
    many thanks
    Roy
    my car is a 52 2.2 dti elite
    cheers
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Must replace the exterior temperature sensor.
    CristianTM.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    It reads like he already has done.
    I had this recently with excessive use of the TC in the snow, but a ignition switch off and on sorted it and its been fine since.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Flippin cold lol sorry dan
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    I had this recently until i remembered i had not reconnected the cable lead on the bumper .
    so i would check out your connection,s.
    cheers for the replys.
    i checked out the sensor again and the wiring to it, i cant see anything wrong at the sensor or plug.
    is there any other plugs it could have come un-plugged from ?
    do you know if it is fused or goes straight to the ecu ?
    thanks for your help again
    Roy
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Can anyone tell me where the sensor is please as mine needs replacing. Its reads .:.. as the temp and vuxhall said it needed a knewen.
    11 Post(s)
    Quote Originally Posted by smiley-sri View Post
    Can anyone tell me where the sensor is .
    Just below and behind the front number plate.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    temp sensor wires go to pins 44 and 47 of the body control module.
    Behind the glove box.
    Shoud be blue and blue/white wires.
    other than this there is a can-bus wire from the body control module pin 40 (green) to the display...pin 28
    If it's not the wiring, then it would be either a dodgey display or a dodgey bcm
    ahh, thank you !
    will trace it out now i know that. i was going to o back to vauxhall to get another temp sensor just to try it but think its highly doubtful
    thanks again, will let you know the outcome
  1. temperature display
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2012, 13:10
  2. Temperature display stuck
    By johnsav in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 13:02
  3. CD Display - Temperature.
    By aaronfenwick in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2009, 16:14
  4. F on temperature display??
    By cameraman in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2007, 16:28
opel astra h outside temperature
zafira outside temperature sensor not working
vectra c outside temperature sensor
vauxhall insignia temperature display
vauxhall temperature display
vauxhall astra f on display
how to reset astra g termometar
zafira f on display
outside temperature gage doesnt work on my astra
astra g outside temperature display
astra g display temperature
vauxhall zafira disolay not showing temperature
outside temp display showing f
vauxhall zafira 2007outside temperature sensor
vectra c temperature sensor showing farenheit
opel omega outside temperature fuse
f to c on zafira b display
opel omega b outside air temp high
vauxhall astra letter f on display
zafira no temp display
opel outside temp say f
outside temperature sensor opel astra
vauxhall vivaro outside temperature sensor
opel astra h outside temperature f
outside temperature sensor on a vauxhallastra 2007 plate
