Results 1 to 10 of 23
Thread: N/S Rear Caliper Binding
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default N/S Rear Caliper Binding
    It's hot after a short run, even in this weather and smells of burning. Also, noticed the car feeling sluggish on acceleration even before checking.
    So, I'm gonna buy and fit myself a new caliper, anyone know roughly who's best to buy from and rough cost? Europarts list this for my number plate and engine
    http://www.eurocarparts.com/ecp/c/Va...bf2b35015&BCAL
    If I get this will I need the rewind tool?? And would Halfords sell that tool?
    Si
    Jun 2006
    Kirkintilloch, Scotland
    Interestingly my rear offsite is binding slightly but unsure as to whether its the handbrake or the calliper.
    What makes you so sure that it the calliper Si ?
    Dave
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    replacing the caliper is a little drastic, remove the caliper remove the pads and remove the dust cover from around the piston (this is probably damaged and will require replacment) get an assistant to GENTLY press brake to bring the piston out chances are there is gunk and corrosion on it that will clean off with a metal polish untill you have a nice smooth piston.
    rewind the piston i use a pair of needle nose pliers in the holes on the piston face turn the piston clockwise as you apply pressure to push the piston back in.
    if pads ok reuse if not replace there buttons anyhow and make sure to check fluid levels
    sorry if you already knew this but from experience people are usually terrified at caliper maintainance.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    When I wanted to service my 302's about 18 months ago, VX had the seals kits on backorder of 3-4 weeks. There were no re-con calipers in the UK, also on back order. Solution - upgrade to 314's.
    Anyway, IIRC, the linky price is cheaper than the re-con/exchange ones from VX. Or, if you do strip the caliper down, just make sure you've got new seals before you start or at least check the current availability.
    Apr 2008
    Wigan
    if its just a edges of the piston you can usually get away with leaving the piston in place just bringing it out a little.
    usually its just the dust seal that perishes
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by cerbrious View Post
    Thanks for the advice, I'll have a look tomorrow in-between decorating the kitchen and shopping for cabinets etc etc
    I took the piston out of my old Frontera and clened it up once, solved the problem for about 4 months then replaced it with a second hand unit. I guess even if this has the same effect it'll delay it til the warmer weather so will give it a go!!!
    I'll check the handbrake cable for any obvious damaged causing it to stick.
    Apr 2008
    Wigan
    never had this only be a tempory fix in the past if you clean it all up properly your laughing might be worth changing the brake fluid soon incase its moisture content is too high
    Apr 2009
    Stevenage, Herts
    MORNING!!
    It's been a couple of weeks, thought I sorted it but now found out I haven't. Gave it a look over to find the pads are down to the last mm, so hoping this was why it was binding I emery-clothed the piston as it was right the way out already, couldn't get the right sized tool and couldn't wind it back with pliers so handed it over to a tyre and brake place to change.
    Now, it's still heating up, only getting warm rather than hot like before, but getting that "burning brake" smell too.
    My question is, if I buy a seal kit, do I need to remove the piston completely to fit, and is it a difficult task?? The dust seal is perished badly also (I do have a pic but it's on another phone).
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    have you got solid discs on the rear as will be taking mine off as going to go vented and 292mm callipers . my old callipers done little millage and no problems if you get stuck
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by simon1 View Post
    Hmmm - I think vented but can't remember, I'll have a look at lunch, many thanks for the offer!!!
  1. handbrake binding rear brakes
    By krisby in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 16:36
  2. Rear brakes binding! Help
    By tonyblade in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 14:00
  3. Rear Brake Binding - 2006 Signum Elite
    By spj555 in forum Suspension, Wheels & Brakes
    Last Post: 25th September 2008, 13:06
  4. rear brake binding
    By corman in forum Handling & Braking
    Last Post: 7th February 2008, 15:03
vectra c rear caliper removal
vectra c brake servo making calipers bind
vauxhall signum rear caliper clean
vectra c rear caliper rubber
vectra c rear caliper change
vectra c remove back rear caliper
how to fit dust seal vectra c
