Results 1 to 10 of 24
Thread: 1.9CDTi Major Power Loss
    Belfast
    Default 1.9CDTi Major Power Loss
    Hello There,
    Im Just finished cleaning the EGR Valve, using the Drill and Punch method, put it allback together, started the car and now there is no power, barely enough to rev on the spot!! there is alot of smoke from the exhaust.
    When i go into the Testmode on the main display, and press the BC button until the "CC" screen is displayed (one with all the zeros) there is a "4" on the bottom row, 10th digit in. (Store Row)
    Please help, My car is now stuck in my driveway as its on a slope!
    Leicester
    Was there a problem before you took the EGR valve apart?
    Belfast
    yeah it was dead upto 2300 revs approx! and then would fly! this pointed to EGR.
    Belfast
    just read a thread on "swirl bar and pots" see here> http://www.vectra-c.com/forum/showth...inlet+manifold
    the wee bar on my car in those pics in the above thread, is completely dislodged and just lying next to the Glow Plugs???
    Leicester
    Inlet manifold required then by the sounds of it.
    Belfast
    are they dear?
    Oct 2009
    Teesside
    About £400 just for the parts
    Belfast
    awh great! i take it all the wee swirl flaps are ment to be in the same position?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    i doubt the swirl bar is your main problem as your car is worse now than when you started!!, go over everything you've done, and make sure you've put the elec connector back on the egr. check how 2's for the 'repair swirl bar for a £1, well worth doing as mine's been working well for a couple of yrs.
    Belfast
    I have since stripped the EGR again and rebuilt it back onto the car... no bolts or plugs missed... will try the £1 fix...
    Thanks for the Speedy Replies Folks!
  1. Major loss of power
    By WeDesign in forum Engine & Drivetrain
    Last Post: 17th September 2012, 13:51
  2. major power loss and engine noise
    By martin.lake in forum Engine & Drivetrain
    Last Post: 17th September 2012, 00:13
  3. Loss of power, 1.9cdti sri 150
    By Lee_Pike in forum Engine & Drivetrain
    Last Post: 16th May 2012, 23:08
  4. EML on and major loss of power
    By chrislloydie in forum Engine & Drivetrain
    Last Post: 20th October 2010, 11:09
  5. Major loss of power
    By martinmack in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2009, 18:58
