Thread: sri cdti 150 55 plate
    Oct 2009
    fife
    Default sri cdti 150 55 plate
    evening all
    just fitted a dmf and clutch a few days ago and now have an intermttent fault where for example;i pull away from a junction but the car refuses to rev.also noticed if i leave it to coast in any gear this problem arises again meaning it is like there is no throttle control.if i slip clutch the revs come straight back to normal and the car pulls faultlesly.definatley intermittent but weird how it started straight after doing the dmf and clutch (fitted an replacement standard filter at same time as old one was filthy (blew the airbox out carefully with compressed air)car due an oil service so would like to get this intermiitent power loss fixed before doing anything else.any advice would be gratley appreciated.
    regards trev
    Jul 2009
    N. Ireland
    this maybe??? http://www.vectra-c.com/forum/showthread.php?t=63811
    im actually having the same problem myself and came on to do a search. Some interesting reading in that thread. I brought the car to a mechanic and was told i needed 3 injectors changed. Got 3 injectors from a breakers (£80 each) and changed them. Made no difference at all so put my original injectors back in. Its now looking like this plug of injector 3 is the problem. Also my car is a 55 1.9cdti 150bhp with 65k on the clock
    EVERYWHERE
    Quote Originally Posted by 9tjc View Post
    You didn't point it at the MAF sensor I hope!
    Oct 2009
    Teesside
    Injector 3 fault on mine I found that at 1800 revs in second gear the car would judder.
    Sounds like it could be related, does sound like an injector fault....
    How to is here:
    http://www.vectra-c.com/forum/showthread.php?t=73584
  1. Vectra cdti 1.9 Sri 120 - 58 plate
    By allysri120 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 09:20
  2. FS: Cat from 1.9 CDTi (120) 57 plate
    By gary k in forum Parts for sale
    Last Post: 16th March 2009, 15:46
  3. 1.9 cdti cam shaft 54 plate
    By ianp in forum Engine & Drivetrain
    Last Post: 11th September 2008, 14:52
  4. 54 Plate Cdti Elite
    By Andy in forum Cars for sale
    Last Post: 24th August 2006, 13:04
