Thread: This May Help Someone - CD70 Navi won't display my satnav maps or graphics..
    Dunstable
    Smile This May Help Someone - CD70 Navi won't display my satnav maps or graphics..
    Hi all, I know this is probably mentioned somewhere else, but when I had the problem I couldn't find a direct answer anywhere. So thought this may help someone with a similar problem. When I bought my new Vectra this month, I had a small problem with the CD70 Navi. Everything worked great, sat nav & everything, but when I went onto the map or arrow display, all that was shown was a black screen where the map should be. After mentioning this to the place I bought the car, they had no idea why this was. After some searching on the internet, I found that the RGB cable between the CID and Headunit only displays the graphics used for the satnav, so I removed the display and alas..the RGB had come free from the back of the screen. I plugged it back in and tried the map display again and everything was fine! I know this is probably an obvious fix for the majority of people on here, but thought it may help those of us that don't know quite so much!!
    Wales, UK
    Definately a good thread, ill bear this in mind should I get any black screens ! And glad yours is fixed !!! I quite like the CD70, good bit of kit.
    Dunstable
    Thanks, was a strange one I must admit. Everything else worked fine with the sat nav, it just wouldn't display the maps!! Seems an obvious answer now but at the time I couldn't figure it out!!
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Now if only the maps were up to date!!!!!
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    This doesn't always fix it...but usually does.
    The rgb cable is the only cable in the entire car that does not have a securing tab to retain it in its socket...
    If it doesn't fix it, then it is a replacement display or head unit job!!
  1. For Sale: Cd70 navi colour satnav full set
    By pszczo in forum Parts for sale
    Last Post: 17th March 2013, 20:44
  2. Post codes in CD70 NAVI satnav - who has this working ?
    By eeyore in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2011, 16:09
  3. Satnav cd70 Navi
    By Chris41 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2011, 21:58
  4. cd70 navi france maps 08/09
    By Flower Girl in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2008, 00:29
cd70 navi blank screen
vectra c sat nav screen doesnt work
cd70 navi with black and white screen
cd70 navi brak map
vauxhall insignia blank screen
cd70 sat nav wont display map
cd70 navi black screen
cd70 navi sat nav not working
maps not showing on cd 70
cd70 navi display
vectra cd70 colour showing black and yellow
vectra sat nav dark screen
sat nav display not working on vectra
cd70 navi screen blank
vectra c navi wont work
cd70 map dark
