Results 1 to 10 of 21
Thread: Help most definitely needed - locking wheel nut removal gone wrong
    Oct 2009
    Belfast
    Default Help most definitely needed - locking wheel nut removal gone wrong
    Hello all, I have screwed up big time.
    Copuldn't get enought torque on my locking wheel nut - thought I hammer a socket onto it to remove it - ponly to realise there is a spinning collar on it.
    Anyone know how to remove a socet from the nut when it's still on the wheel.
    Please please help......
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    tap it side to side mate
    Oct 2009
    Belfast
    thanks for the quick reply - unfortunately I have been trying this for ages but it wont shift - I gave it a pretty soplid hammering to get it there like.
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    er get a ratchet in it mate try wiggle it about with that all else failing get some heat on it mate
    Oct 2009
    Belfast
    Cheers - had a ratchet on, not tried heat yet - will give that a go.
    Any other suggestions?
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    er no lol drill a hole in each side pu somet through it atach it 2 a car and give it a pull with the other car becarefull though
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    slide hammer every time
    Mileage : 000
    Is the socket still sticking out from the wheel, Is it possible to get some mole grips (the type that lock) on the socket and pull. Put some wood or anything that will protect the wheel and lever against it.
    Oct 2009
    Belfast
    The socket is almost flush with the wheel. Have been thinking about a slide hammer - how would I get it to attach to the socket - there is only the small square hole in ths socket.
    I'm starting to panic now....
    Thanks again
    Apr 2008
    Wigan
    if theres room use a hook type attachment through the drive hole if not either drill and tap or use a self tapper
  1. removal of vx locking wheel nuts
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 9th February 2012, 00:10
  2. New steering wheel control needed SMD conversion gone wrong
    By chuckleuk in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2011, 21:18
  3. Locking wheel nut removal
    By Critch in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 19th May 2011, 20:37
  4. locking wheel nuts help needed asap
    By winnie2457 in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2010, 10:13
  5. Locking Wheel Nut Removal
    By HHH in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2007, 14:58
