Results 1 to 10 of 11
Thread: How to tighten the Aux Belt ??
    Aug 2009
    UK
    Thumbs up How to tighten the Aux Belt ??
    The Aux / Alternator belt is loose on my vectra 2.0 DTi and its making a screaching sound everytime I drive. I'm trying to get to the hex bolt that loosens the tensioner (located underneath the tensioner) so that I can reposition the tensioner pulley and then re-tighten it. The problem I am facing is getting the rachet and socket onto the hex bolt because there is no space and the tooll keeps hitting the framework.
    Do I need a special tool or is there an easier way? Can some provide an how2 or step-by-step guide please.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i need this doin on my car 2 mate gonna watch this page now lol if you find out let me no please mate
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    The tensioner is self tensioning any way so you wont be able to adjust it, basically the little shock wears out and elongates the lower hole so im affraid a new one needed, just as well replace belt while your there.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    how much cost is involved mate
    Nov 2007
    weymouth, dorset
    Not exactly sure, think the tensioner comes complete with idler pulley as well and is about 80 quid, belt is about 30 but again not exactly sure on those mate.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Most common failure on the dti tensioner is that it seizes and doesn't self adjust. To change the tensioner (40-50 quid) you'll need a torx spanner as one of the two bolts is close to the chassis leg
    Belt is around 20 quid from the stealers
    Regular Member bradley's Avatar
    Hartlepool
    Quote Originally Posted by paulvectrac View Post
    £10.99 aux belt and around £30 - £40 for the drive/alternator belt tensioner, thats from a parts place, if you go to stealers it will be £58 for the tensioner and £15 for the belt
    also if the belt wheel has excessive play in it that will be £25 from stealers
    hope that helps
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    cheers mate gonna be cheaky now any one got part numbers please is it easy to fit
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Here is the tensioner http://cgi.ebay.co.uk/SIGNUM-SINTRA-...item4ce8c58207
    Belt is part no. 55354681
    Hartlepool
    mmm?
  1. Handbrake tighten
    Last Post: 22nd March 2012, 15:00
  2. Tighten Boot Lock
    By barachello in forum Bodywork & Interior
    Last Post: 13th June 2011, 15:19
  3. Dont forget to tighten your lap belt!!!
    By rushy in forum Comedy & Humour
    Last Post: 6th September 2006, 20:26
https:www.vectra-c.comforumshowthread.php98272-How-to-tighten-the-Aux-Belt
holden vectra alternator belt adjustor
2.0 dti auxiliary belt
vectra c alternator belt
how does the alternator belt go on vectra 2.0dti
vectra c alternator belt tensioner
aux belt tensioner vectra c 2.0 dti
changing alternator 2.0dti astra van
vectra b auxilliary.replacement
vectra auxiliary belt tensioner
how often should i change the drive belt tensioner on a vectra c
04 vectra drive belt fitting 2.0dti
zafira dti auxiliary belt change
vauxhall vectra 2002 auxilary belt
how to tighten fan belt vauxhall astra 2.0dti
2.0dti belt tensioner loosening
how to tighten alternator belt vectra c diesel
where is the alternator situated on a vauxhall vectra c
zafira dti aux belt change
astra loose aux belt
vauxhall vectra alternator belt diagram site:www.vectra-c.com
does a vauxhall vectra have a self tightening alternator belt
vaxhull vectra belt tentioner loosen
vauxhall zafira alternator belt tensioner
how to fit a tensioner on a 2.0dti alternator
