Thread: How to change gear lever
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default How to change gear lever
    Hi guys any one changed gear lever in vec? looking yo do this monday- any one any suggestions?
    Andy
    What bits exactly are you changing mate? If it's the whole thing including the black plastic base it's a piece of cake. 4 torx scres hold the base down, and one ball joint right at the bottom connecting one of the selector rods. the other rod is pushed on to the base itself, which you'll see when you take it off.
    Ten minutes, tops...
    Jun 2009
    bradford
    Thumbs up
    Quote Originally Posted by Penfold101 View Post
    yes cheers Penfold -whole lot with base! does the console need to come out? by the way thanks for your help
    Nah, one T20 torx screwdriver and you're sorted. The only tricky bit is pushing the ball joint back together - you'll need a bit of ingeuity to wedge it against somethign to push it back in. I also had issues with the gaitor as mine was off an Astra, but if yours is from a vectra it shouldn't be an issue...
    http://www.vectra-c.com/forum/showth...t=knob+modding
    Jun 2009
    bradford
    thanks again Martin. supposed to have done a search.....but
    thanks for the help............P.S..looks good, mines just a vectra one but chrome instead of the crappy silver paint that scrapes off with ****** ring on
    To be honest mate I'd be worried about what you were searching for if you'd found that...
  1. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  2. gear lever change for auto vec c v6
    By v6 sri diesel in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 18:32
  3. VXR Gear lever
    By Derek Mc in forum Styling
    Last Post: 2nd June 2010, 20:19
