Results 1 to 10 of 11
Thread: Noise - sounds like a window open!
    Stoke-on-Trent
    Default Noise - sounds like a window open!
    Hi, has anyone experienced undue noise from outside the car that sounds like a window could be blightly open? It's worse on wet days from passing traffic. I've checked the window/door seals for anything obvious and looked for missing grommets. The car has the original windscreen and I've even looked behind the tweeter on the drivers door to see if there was any gaps underneath.
    Does anyone have any suggestions that I could check, or have any similar experiences. Feedback gratefully received. Thanks
    WGAF#5
    are you getting any moisture in the car ??? could be the windscreen seal has popped - not uncommon or unheard of - might also be a failedor distorted window seal do you have any problems opening or closing the windows?
    Stoke-on-Trent
    Thanks, I've not had any moisture or noticed any problem with opening the windows, I will take the car to Autowindscreens and ask them if it's possible to check the windscreen seal as I can't really check it myself.
    Thanks again.
    Sunny Dartmoor
    Might just be the door rubbers have worn when opening and shutting the door,remedy for that new door rubber maybe........
    Stoke-on-Trent
    Question
    Thanks, the inner and outer door seals look to be in pretty good nick, the car is a low mileage facelift. I must admit that I had wondered about the windscreen seal as the sound seems to be in front of me, there's no wind noise or water ingress though??
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Do you have wind deflectors?
    Wales, UK
    Might be silly advice but I get the same noise, the cure is winding the back windows up ! Over time, the manual winders seem to drop and slightly open the rear windows ?!?!?!
    Might be, you never know !
    Stoke-on-Trent
    Thanks, no wind deflectors, does have manual windows at the rear though
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    As Mark 647 says....I've found that also....Cheers
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    yup mine do same
  1. Bad time to leave your window open!!
    By kicker in forum Comedy & Humour
    Last Post: 14th December 2012, 10:14
  2. Return to car and drivers window is open on its own????
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2012, 00:47
  3. Replies: 0
    Last Post: 17th January 2011, 23:43
  4. Sounds like a rubbing noise
    By Gortreck in forum Suspension, Wheels & Brakes
    Last Post: 2nd March 2010, 11:37
  5. How to open just the drivers window
    By Elite2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2006, 21:02
