Thread: 3.0V6CDTi - Oil Cooler
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default 3.0V6CDTi - Oil Cooler
    Might seem like a dumb question to some of you, but does the 3.0CDTi have an oil cooler? I'd like to have a cooler to keep the oil around the 110°C mark or is this a bit too optimistic?
    Feedback well appreciated
    Bristol
    Yes there is an oil cooler on the front of the oil filter.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Good. That makes things easier.
    Can I replace it with a more "powerful", bigger unit?
    Bristol
    I don't realy know. You can't see the top of the filter unless you take the radiator out.
    I don't see any benefit to doing so as the engine should be pumping the oil through it at a predetermined rate
    Equally, VX don't seem to do a larger one
    Adding a larger one may have consequences as the oil capacity will increase and the oil pump may not be strong enough to cope with the increased pressure
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by sb1uk View Post
    Is it a heat exchanger-thing or a proper oil cooler?
    It looks more like a simple heat exchanger (matrix)
    Search google for : 13106816
    I originally thought it was part of the air conditioning system!
  1. Oil cooler
    By Dimscreen in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 22:42
  2. oil cooler and Gsi.....
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2010, 04:04
  3. Cooler box
    By SIDNUM in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2009, 17:04
  4. 3.0V6cdti Poor Performance
    By Les Scott in forum Engine & Drivetrain
    Last Post: 30th November 2008, 15:56
  5. Replies: 31
    Last Post: 20th September 2006, 09:08
