Results 1 to 10 of 14
Thread: Screeching sounds when cold?
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Default Screeching sounds when cold?
    Hey all ive got that nasty screeching sound when i start the car from cold i think its some sort of belt but not sure can someone advise and direct me to a how 2 if there is one?>
    cheers
    Feb 2007
    North west
    can be aux belt but can also be water pump screeching. You can get a lube to add to your coolant for water pump, if its the aux belt you can feel slack in it - should be really tight.
    Nov 2007
    Leeds
    which ones the aux belt?
    Full Member Big Sig's Avatar
    The one that goes round the alternator.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    the ribbed belt that drives auxillary units, alternator,air con pump,ect
    Nov 2007
    Leeds
    ahhh right ok is it easy to change? is there a how ttoo knocking around?
    Jul 2009
    Engine : 20 Dti
    just a bit fiddley
    Jul 2009
    Engine : 20 Dti
    sorry BS we answerd together
    Wexford Ireland
    It may only need tightening up which is easier than replacment. Have a look and see if itis worn bad.
    Quote Originally Posted by garethIreland View Post
    Don't they all have spring loaded tensioners?
    What engine is it for?
  1. screeching when starting ??
    By mccluskey119 in forum Engine & Drivetrain
    Last Post: 9th August 2011, 23:52
  2. Replies: 0
    Last Post: 17th January 2011, 23:43
  3. Front brake screeching!
    By Mogsy007 in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2010, 20:17
  4. Lowering problem - Screeching
    By jamesr in forum Suspension, Wheels & Brakes
    Last Post: 21st November 2008, 15:03
  5. Knocking and screeching
    By Fulgrim in forum Troubleshooting
    Last Post: 12th May 2008, 17:42
vectra c diesel screeching from cold
