Thread: Intermittent Power Steering problem
    St. Neots
    Default Intermittent Power Steering problem
    Hi,
    I have a 2005 Vectra 1.9 CD-i and a couple of weeks ago the power steering packed up and a warning light came up on the dashboard. I switched the engine off and back on again but no change. After a couple of days it started working again. Then stopped again a few days later. I checked the fluid levl and it's fine. Also I disconnected the pump and reconnected it to clean the connectors but to no avail. I had my mechanic put the laptop on it and the result was 'cam bus no communication'. His laptop also came up with other faults that i didn't know existed. Is there a wiring fault or is the power steering pump on the way out?
    Nov 2009
    Luton
    any tc lights or anything? looks like it may be the CIM (column intergrated module) on its way out
    St. Neots
    There's a light on the dash (steering wheel & exlamation mark). Got it booked in at vauxhall dealer tomorrow.
    Regular Member ServerKing's Avatar
    My Dealer's service yard... (sigh)
    How did you get on with the steering fault?
    The dealer told me when I took my Vec in that the ECU (£540 ex vat and labour) would have to be replaced, and the alternator (£245 ex vat and labour) would need replacing as the low charge was affecting the ECU and the steering. Hmmm... the battery still retained it's charge and never died
    In the end due to the high running costs, I had to get rid of it. My steering wouldn't communicate with the ECU either, that's a classic symptom. My independent mechanic told me that when a steering pump fails, it fails completely, it never springs back into life.
    This one had him stumped as well. It all points to a serious electrical failure, and this intermittent fault will never go away.
    All the dealer will do is Tech2 it and say they can't fix it, it's sod's law that the car will behave itself on the day
    Southampton
    im having this same issue but with a 2006 1.9 tdci it work most the time in the summer but in winter it can be a little dodgy
  1. Power steering problem
    By Danwells72 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 16:25
  2. power steering problem
    By mr.d in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:33
  3. Intermittent loss of power steering......
    By 1ctchris in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2011, 10:20
  4. power steering problem...!!!!
    By rioni in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2011, 18:36
  5. Intermittent Power Steering Failure
    By sol in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2011, 16:15
vectra c intermittent steering problems
vauxhall vectra 1.9 power steering to ecu
