Thread: Newbie 1.9 CDTI 150 owner
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Default Newbie 1.9 CDTI 150 owner
    Hi all,
    Just bought a 1.9 cdti 150 sri, has 32.5K on clock, there was no service history with it so aam looking to start a maint programme on it. Any tips as to things to check for as signs of pending faults while it still in its 3 month warranty?
    So far it seems sluggish for the power and torque it should have and I got better MPG the 1.8 petrol it replaced, I have it booked in to Evans Halshaw in Leeds in the new year to look into. it also seems to struggle in 6th gear at 70 is this normal?
    thanks for any tips
    and Merry Xmas to all
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    could be sticky egr or swirl pots. look at the how 2 on here to clean the egr
    as for sevice book it in for a full service or a diy service i would do
    oil and filter
    fuel filter
    air filter
    brake fluid check
    discs and pads replace if needed and a general good look around for faults or worn parts
    hope this helps mate
    Regular Member ba1ny82's Avatar
    hull
    hi there and welcome. good car nearly got one my self but instead opted for the 1.8 petrol sri 140.....
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Cheers guys will have a look at them, can carb cleaner be used on the EGR?
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    the main dealers should be able to tell you about the cars service history ...
    and yes your car sounds sick .....get it looked at b4 warrenty runs out
    Leeds
    FYI - was told to avoid Evans Halshaw in Leeds like the plague, advised to use Evans Halshaw in Wakefield - which I did for my SRi CDTi 150 and can't complain - very good service.
    My thread about them here - http://vectra-c.com/forum/showthread.php?t=78074
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    yes carb cleaner is fine, check the how 2 for cleaning the egr (dont forget to clean the hole in the inlet manifold to where it fits!!.
    May 2007
    West Yorkshire
    Quote Originally Posted by julian924s View Post
    I have used both (warranty work on my own car and general servicing on old co cars) and find them both atrocious. Wakefield will never do anything other that warranty work from now.
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by clightowler View Post
    Hi all,
    thanks for any tips
    hi there mate and welcome.
    i have got the elite cdti 150 and not to rub your nose in it but no that aint nowhere near normal at 70 it should pull like a fricken steam train and i recently travelled to loughborough from wales 143 miles and got 51mpg out of it average i aint bragging mucker just letting youy know what you should expect from yer motor
    merry x mas to you sir
  1. newbie owner
    By dinger in forum Introduce yourself.
    Last Post: 11th October 2010, 18:22
  2. Newbie owner
    By malk in forum Introduce yourself.
    Last Post: 30th March 2009, 16:58
  3. Newbie SRi owner
    By julian924s in forum Introduce yourself.
    Last Post: 6th December 2008, 19:34
  4. Newbie Vec C owner
    By KieronGSI in forum Introduce yourself.
    Last Post: 1st May 2008, 15:24
  5. Newbie GSi owner
    By grunners in forum Introduce yourself.
    Last Post: 27th November 2006, 16:32
