Thread: Vectra 1.9cdti Xenon Lights
    Oct 2009
    Hertfordshire
    Default Vectra 1.9cdti Xenon Lights
    Hi, my passeneger side front indicator has stopped working. I tried to fit a new bulb but it was impossible to get into the unit. After speaking to a vauxhall dealer they said that as it's a xenon directional unit which had to be done via a professional as the bumper and grill needed to be taken off. They took it in (£101.00 ouch) to change the light bumb to discover that there was a fault with the unit itself and that i would need a new head unit which would be £550 plus labour. I cannot believe it's that much!!!! My question is does anyone know where i can get a unit from online? I know someone who could fit it. If not does anyone know whether I could replace both front units for a standard vectra lamps and whether this would be a straight swap for a pro?
    Thanks and Merry Christmas
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    You can swap them for standard units if you make the necessary changes to the loom and also spend an hour at the stealers having the AFL switched off with Tech 2, still gonna cost you sorry mate.
    Without the cost of the new lamps being included, its probably cheaper to have the AFL lamp replaced in the long run.
    Leicester
    It's about a 10 minute job to remove the bumper and headlight, but as Big Sig has said, probably best to look for a complete headlight unit off the likes of ebay for a couple of £00 at the most.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    I found this on the web
    4th & 5th down
    Click me
    hope it helps
    Quote Originally Posted by Thunder View Post
    I found this on the web Click me
    hope it helps
    Don't think thats a xenon or afl light
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    i edited it
    i edited it
    That will be the ones
    4th & 5th down
    Click me
    hope it helps
    I shall keep these in mind - painful but may be necessary...
    Oct 2009
    Hertfordshire
    Thanks everyone for your reply. It seems that when it's above 3 degres .I.e before the temprature light comes on it's ok, but as soon ad that light says it's cold, the bulb then stops. Does anyone know a way of getting the light out? How do you remove the bumper? Thanks
  1. XENON AFL lights
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2012, 11:43
  2. Xenon Lights...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 12:15
  3. xenon lights too low??
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2008, 21:31
  4. Have I got Xenon Lights On My 07 Vectra Elite?
    By Gordon B in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2008, 02:40
  5. Xenon lights too low
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2007, 22:12
vectra 2008 xenonai
