Thread: help, im starting to hate my vectra
    playing with spanners
    Default help, im starting to hate my vectra
    The oil light came on the other day at idol, when I reved it.the light went of, now every time the car is at idol the light comes on, my mate said it could be the oil pump, is the car still ok to drive as I need to use it over christmas, thanks
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Is the oil level ok on the dipstick ?
    If yes, then it could be the oil pump.... could be the oil pressure switch.... could be a blockage somewhere...... could be... could be... could be.....
    If the physical level is good and the light stays out if you rev it, I'd say take it carefully and get it checked out ASAP.
    Oct 2009
    Teesside
    What HandyAndy said, check the oil level and if all ok then probs a faulty sensor somewhere!
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Could be your Oil Pump as the light being on at idle suggests low oil pressure. Have you tried a oil and filter change as this might help if you havent had a service for a while the oil could be knackerd or the filter blocked. The other thing it might be is the engine itself because if its high mileage and worn this can cause the same issues. I have had all these things happen to me in the past with various cars I have had but not my veccy thank god
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    wouldn't hurt to try a sensor first
    Tar everyone , got a sensor on order for tomorow morning
    Regular Member videodoctor's Avatar
    Blackpool
    Quote Originally Posted by bigron1988 View Post
    I would like to see you pick it up on Christmas Day
    Edinburgh
    May 2008
    Derbyshire (south)
    I had a similar issue with My gf's, but for some reason, it was the chrome trim pipe that caused this. After i took it off, iits never done it again & been fine too.
    My mate works at a garage and they order parts b4 9 in the morning, they get them at 11,
    Got it sorted today , it was the sensor, oil was ****ing out of it, chears everyone
  1. i hate my vectra
    By chunkymunky in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 14:43
  2. Starting to like my vectra now !!!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 01:07
  3. HELP!! Am starting to hate my signum! :(
    By edwardabud86 in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2009, 22:58
  4. vectra not starting
    By carl in forum Engine & Drivetrain
    Last Post: 28th December 2007, 03:10
