Thread: Strange Wiper Fault
    Dumfries and Galloway Scotland
    confused Strange Wiper Fault
    Today my wipers appear to have changed their home posistion.
    Instead of laying flat ie at 9.00 o,clock from the Driver Seat view, they now stay at 12 0,clock, they work normally in every respect other than the home posistion being 12 o, clock which is very off putting when they are not in use. any of you have any idea of what is going on, many thanks
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Default Simple check
    Take a look at the bracket where it fits to the motor itself.Should sort of point directly to front drivers side wing.If not most prob the nut has come loose moved the bracket then sort of gripped again. There is a How to on changing wiper linkage on this site just search and you will see a piccy of what i am talking about.
    Nov 2009
    Luton
    wiper motors are common on these, im sure you can just buy the motor without linkages though
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Mine play - up every winter when the outside temperature drops to around freezing or below...there are several posts on here with guys similar experiences.. check in Search....I tap the wiper stalk down to until they get to the normal parking position.
    When the car has been parked up for a while after a run, they work normally again until next time the temperature gets down to freezing of below again when the car has been stood for some time.......
    The car is a 55 reg Facelift Club Hatch with the Z18XE pre VVT engine....
    Full Member Big Sig's Avatar
    Were they frozen to the screen when you went ot use them? they may have slipped on the shafts due to operator error!
    Many thanks for all your thoughts, turned out to be the bracket that connects to the motor itself.
    It had spun on the shaft 180 degs think it probably happened whilst trying to get rid of Snow from the windscreen.
    Repaired at no cost other than my time I like those sort of repairs
    Thanks again
  1. strange heater fault
    By DAVIDD88 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2012, 21:27
  2. Focus mk2 strange wiper prob!
    By signum_rob in forum General Motoring Chat
    Last Post: 4th June 2012, 20:50
  3. strange headlight fault
    By toast in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2011, 07:26
  4. strange fault symbol!
    By oldcommando in forum Engine & Drivetrain
    Last Post: 25th April 2010, 17:26
  5. Strange fault
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2009, 15:52
vectra c wiper fault
