Thread: Can spray painted wing mirror for the 1st time
    Regular Member L11Marc's Avatar
    May 2008
    Liverpool
    Default Can spray painted wing mirror for the 1st time
    and the result was crap!!!
    Been 3 days since I aerosol spray painted it and lacquered, but in between I did not wet/dry or sand inbetween coats, parts looked more darker than others and jet washed it today and the paint has peeled off back to the colour I got it off Vauxhalls (grey primer).
    Regular Member Jezzy's Avatar
    S.E
    Something gone wrong there fella - I did exactly the same thing, i.e. bought a grey-primered cover and sprayed it myself, and the results are very good; a year and a half on and no one has ever noticed it's a DIY job.
    I did however flatten it with soaked wet'n'dry paper after almost every coat, except the last topcoat and the 2 or 3 coats of lacquer. All in all it was about 10 coats.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    how long did you leave to dry between coats?
    May 2008
    Liverpool
    Quote Originally Posted by leemarksmith View Post
    About 45mins. My 2 problems are the weather (the wing mirror is on the car) and spraying too much in 1 area so it looks patchy and darker in places. Really ****ing me off the money I spent on it and Vauxhalls cannot even provide a silver lightning wing mirror!!!
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Have you not tried popping the mirror covers off and get them sprayed in the kitchen where its warm... but the paint stripping off is kinda worrying. can only think theres a problem with the paint there... spraying in the cold too will make it duller then it should be...
    If they where my covers i'd do em in the house, and bang them in the oven on a low heat in this weather between coats (leccy oven only)...
    Birmingham
    You may be better off just ebaying it.
    Heres a few Silver Lighning Breakers: http://cgi.ebay.co.uk/Vauxhall-Vectr...9#ht_500wt_956
    http://cgi.ebay.co.uk/vauxhall-vectr...#ht_886wt_1165
    HTH and best of luck.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member anthonychall's Avatar
    Apr 2009
    Liverpool
    your best bet would of been ebay mate or a breakers! me cousin owns a body shop in old swan in l'pool. he could spray it and that for u for about 30 quid if tha
    Birmingham
    Not worth it IMHO. You are better off ebaying it and trying to flog your old one back on there for whatever it makes!
    Bye bye Vec B
    - Hello Siggy!
    Bristol
    When you spray the base coat do not rub it down. just spray clear coat on top. then wet and dry it and then polish.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    It is very unwise to attempt any spraying at this time of the year, unless the item can be removed to a warm area. The moisture in the air at this time of the year affects the paint and gives you the well known "orange peel effect". I managed to can spray my old Rover rear fender last year but only by taking it into the dinning room and sprayed it by the radiator, that went down very well with my wife she said it stunk the place out, myself I thought it added a certain charm for our guest's.
  1. spray painted side skirts
    By luke.oldham in forum Bodywork & Interior
    Last Post: 25th February 2011, 22:06
  2. Wing Mirror
    By m19cpb in forum Insignia car chat
    Last Post: 27th November 2010, 18:11
  3. Wing mirror
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2010, 20:28
  4. Wing Mirror
    By tammyman09 in forum Bodywork & Interior
    Last Post: 4th August 2009, 14:52
  5. wing mirror
    By test_uk in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2008, 21:15
