Thread: Limp mode
    Regular Member griffgrin's Avatar
    Jul 2009
    wrexham
    Default Limp mode
    Ok this is the problem ive got, 2 months ago on way to bath from north wales
    about 10 miles from bath doing 70mph cruise control on all of a sudden revs dropped, power lost, spanner light on dash, pulled over stopped engine, restarted it all ok full power etc A week later on way to stafford it went 2 times again got home spray wynns egr cleaner thru seemed ok for about a day then light and power loss again, wont rev past 3000 rpm noisey rattley etc.took egr valve off full of crap cleaned it disconnected battery to reset any codes etc ever since the ive got no spanner light but still no power mpg down to 35ish ( by the way its a 03 2.0 dti) it seems to be permanently i limp mode. any ideas please.
    Regards
    Terry
    fife
    the same thing happen to me about 4 weeks ago i got a freined to reset the dash and look at the fault codes. took it to the vx dealer yesterday and they replaced the egr valve .will try the car out tomrrow cause im not working to day(my cars a 1.9 06 vectra)
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi griffgrin you have the commonest fault with the 2.0 DTI ,s unlike xc600 post i would not go to the extreme of having it replaced .
    If you know anyone with a tech 2 or an op-com have your fault codes read to diagnose the fault or take it to the stealers to have it read , will cost anything from £35 to £80 for stealers to do. failing that try cleaning the egr yourself and boost sensor yourself.
    Remove the egr its only held on by 2 bolts and two hoses unplug your electrical connection and give egr valve a clean out with carb cleaner ,making sure the valve can lift freely .
    While your there also remove your boost sensor and clean that up as well with carb cleaner
    While your soaking the egr valve check all your hoses and vacuum connection,s for splits another common cause of vehicle going into limp mode these tasks will solve 90% of limp mode faults on the dti,s
    and still loving it
    fife
    handy to know
    Jul 2009
    wrexham
    Hi Bobssignum, i have done all those things ie egr valve off, clean replace, Boost sensor, off clean replace hoses checked tightened etc still driving like a bag of spanners, so frustrating or what.
    Regards
    terry
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Check all of the small vacuum pipes that run around the engine bay, sometimes the rubber ends can split
    Jul 2009
    wrexham
    Thanks john ill go and check them again.
    Regards
    terry
    Nottinghamshire
    Check the vacuum pipes themselves as well and also check the large air pipes while you're under there.
    It may be worth calling a dealer and seeing if your car needs the turbo re-calibration done.
    I had mine done last week as it was and update and free although I wasn't having any problems. Good going VX - the car's only 7 years old!
    Engine : 2.0DTi
    Mileage : 73350
    Terry If you ,ve gone that far and still no joy it begs the question did you have it tech 2 ed at any time, and if you did what were the results
    Some thing that will not show up on a tech 2 but will give you the same symptoms/problems is the actual vacuum actuattors themselves .
    check to see if you have a vacuum at the outgouing port on each actuattor , there should be three of them each actuattor operates to 0.6 bar which is detectable with a wet finger . also check the vacuum pump on the end of the cam as i have heard of these going faulty as well.
    and still loving it
    Jul 2009
    wrexham
    Ok ive just checked smaller vacum pipes and there was one loose it was a white thin one that plugs into something next to the radiator it will now rev past 3000 rpm but still no guts and noisey. as for the tech 2 issue ive never had it done, to be honest it goes right over my head and no idea what it is or means, sorry if i sound a bit thick.
    Regards
  1. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  4. Limp mode
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
