Results 1 to 10 of 23
Thread: fffffreeeeezzzzinggggggg
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Default fffffreeeeezzzzinggggggg
    hi muckers
    has anyone got the same problem as me , everytime we get a big frost (which is often at the moment )
    the front and back windows get a lot of frost inside the car ,
    is there a tell tale sign here like the window seals are going or is it just a common thing we all have to live with when we bought our pride and joy.
    regards all
    and merry merry vectra to you all
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Seems to be an all too common problem. Someone mentioned the condition of the pollen filter can affect this - I'm guessing that an old, clogged pollen filter retains more moisture, so you'd be sucking damp air into the cabin most of the time which in cold weather becomes more obvious.
    Best I change mine PDQ then
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Try closing the air vents on the dash that are letting the cold air in.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I would check the pollen filter. Just replaced mine so havent had the inside frost but my god.. the old one was disgusting! And weighed like 50kg looool.
    It could just be the moisture if you have brought a lot of water or snow inside over the past few days.. i.e. wet carpets?
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    how often would you suggest changing the pollen filter my car is an 08 and don't think it's been done yet
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Never had this problem tbh.
    Oct 2009
    Bilbao&Madrid
    Vehicle : Opel Signum
    Trim : Cosmo
    Engine : 3.0 CDTI Z30DT
    Another interesting measure against internal condensation is to clean all the internal glass surfaces thoroughly. I used to apply a product from Autoglym, "glass polish", "glass cleaner" or something like that, with good results.
    It did such a good job of preventing condensation that when I was with my girlfriend waiting for ... o, well, you can guess what (didn't) happen.
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    do not apply the autoglym glass polish on tints i was stupid enough not to read the instruction and it started to burn off my tints on my previous car
    West
    Never had this problem either... replace pollen filter clean out the water drain hole below the filter & run the aircon on recirc with the heat up to help dry the moisture from the inside of the motor... hth
    Wales, UK
    Ive been getting a lot of mist on the inside, replaced the pollen filter and hey presto. Only takes 5 mins mate, no tools required and mine was £10.75 from the dealers.
    Also, apparently - rubber mats cause a similar pro by holding water ??
