Results 1 to 10 of 16
Thread: Whats the normal operating temp when moving?
    Ireland
    Default Whats the normal operating temp when moving?
    Hi all - just wondering what the engine temp reading should be when on the move (not in traffic) with the Vectra C - mine moves all the way pointing left as if the engine is cold but when in traffic it will steadily rise to pointing straight up. Is this normal?
    Last car i had the temp guage just stayed around half way whether in traffic or on the motorway...
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    It should read cooler when on the move due to the cold air going through the engine.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    In this weather mine is around 70 degrees when on the motorway and about 80 degrees in traffic, however in the summer it is about 85 degrees normal and 90-95 degrees in traffic, quite normal remeber the time of year there are lots of threads asking similar questions, it may not move at all depending on the length of journey.
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Quote Originally Posted by devore View Post
    The gauge should always read between 80-95 degrees on the move no matter what the weather , only thing is it takes longer to reach operating temperature from a cold start in these conditions. If your not getting that then I would suggest you change the thermostat
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    My 3.2 was sitting nicely about 83/84 as I came up from London last weekend - Outside temp was showing between +2c and -3c through the journey.
    In general terms through the year's temperature it seems to hover somewhere between the 85-90 markers.
    Regular Member P3tchy's Avatar
    Milton Keynes
    Mine sits at 88 pretty much all the time either cruising at 80 or stationary, but thats only since changing the stat at the weekend and flushing the coolant.
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Mine sits a slight tad over half way mark in normal weather and just under out in this.
    Regular Member garvey's Avatar
    Co Durham
    Mine on freeezing cold
    Mileage : 000
    Quote Originally Posted by Handyandy-UK View Post
    Sounds about right. Mine does the same.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I thought if it dropped all the way down on the temp gauge it meant that the thermostat was gone? Even when it was minus 18 here at 40mph it wouldnt really go below 80. Just took a long time to get there! It usually sits just under half way, but in Italy when it was red hot it was at around 92/93.
  1. normal cdti 150 temp??
    By elite_150 in forum Engine & Drivetrain
    Last Post: 6th June 2012, 08:57
  2. Temp gauge not moving!
    By twinxster in forum Engine & Drivetrain
    Last Post: 10th February 2012, 21:06
  3. preface 1.8 temp dial slow to get moving
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:50
  4. 1.9 CDTi (120) - Normal Operating Temp?
    By vec1975 in forum Engine & Drivetrain
    Last Post: 1st May 2009, 20:10
  5. Normal operating temperature?
    By runs4miles in forum Engine & Drivetrain
    Last Post: 28th April 2008, 20:54
