Thread: Trouble starting
    Larkhall
    Default Trouble starting
    Lately the Vec has been taking ages to start when it's been left overnight or while ive been at work.You can hear it trying to turn over............
    The glow plugs are heating up fine and the alternator is charging but i have no idea what could be causing it
    Leicester
    What fuel are you using?
    West
    Any eml & what's the condition of the battery
    Larkhall
    I've been using sainsbury's and shell diesel and the eml shows up when the car starts but goes off a few seconds later - this only started to appear when the manifold was changed.
    the battery is fine as well
    West
    Quote Originally Posted by T4M View Post
    If it's doing this on the cold starts only... then that does usually indicate a faulty glow plug
    Larkhall
    i'll get them checked again
    if i've been using the car then it starts fine but if its been left for hours then it takes its time lol
    N.Ireland
    My light was staying on for a couple of minutes,I had one dead plug no.3 and the other three seemed to be weak,so I changed the lot but the light still comes on now when the ignition is switched on and goes out as the car starts up.
    Leicester
    Sainsbury are still apparently using summer diesel as it's cheaper. It hasn't got the antiwaxing ingredient which if used in the winter, will cause fuel filters to block.
    Regular Member Jezzy's Avatar
    S.E
    [quote=Maverick;1125853]Sainsbury are still apparently using summer diesel as it's cheaper. It hasn't got the antiwaxing ingredient which if used in the winter, will cause fuel filters to block.[/quote]
    I'm sure you know what you meant.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    nobody would sell fuel to the general public at these temperatures without the additive!, i think youl find its put in automatically at the refineries regardless of who's buying it.
  1. Having trouble starting car
    By Tombird in forum Engine & Drivetrain
    Last Post: 7th February 2013, 23:26
  2. Trouble starting
    By Daywalker in forum Engine & Drivetrain
    Last Post: 9th February 2009, 17:55
  3. 2.2 DTI starting trouble
    By Costlyspy in forum Engine & Drivetrain
    Last Post: 8th July 2008, 19:14
  4. Trouble starting.
    By Gr4eme in forum Troubleshooting
    Last Post: 24th February 2008, 22:27
  5. Trouble Starting
    By JCB in forum Engine & Drivetrain
    Last Post: 7th February 2007, 12:34
