Results 1 to 10 of 19
Thread: Windscreen washer jets failed
    Regular Member mr-s's Avatar
    Sep 2009
    Shropshire
    Default Windscreen washer jets failed
    Still reeling from the power steering fault, i was hoping for a few trouble free months from Siggy.
    It didn't last long
    Both front washer jets have stopped working.
    Initially i thought the obvious - frozen up, but after running warm water over the nozzles and connecting pipes, im still getting nothing after 3 days.
    The motor works, as does the rear window washer jets.
    Ive tried attempting to 'wash' the windscreen, to check for fluid leaks under the car from a dis-connected pipe, but ive found nothing as yet.
    Has anybody got any idea's, because having to keep pulling over to manually 'wash' the windscreen with a bottle of water is becoming a tad annoying.
    Thanks,
    Scott.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Had this on my Cougar once. All you can do is get the washer reservoir motor out (On the cougar it was from under the car) and get someone to apply the switch. If its spinning then you must have a blockage somewhere either in the reservoir or the tubing..
    I bought a new motor for the cougar but once we pulled it all out, I found that it was just gunged up. Hope that helps sort it.
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    There is a small filter on the pump at the reservoir , this is prone to blocking in this weather. Need to access it from under bumper/wheel arch area on the passenger front. On my last vec-c removed the small filter altogether
    leicestershire
    Corrrect daviek had this on mine too give it a try
    ayrshire scotland
    Quote Originally Posted by Xpolicevectra View Post
    Most common causes are using cheap screenwash , no screenwash or washing up liquid in the reservoir
    Sep 2009
    newcastle
    Smile
    i had the same problem removed filter and now works fine
    Sep 2009
    Shropshire
    Quote Originally Posted by daviek View Post
    Cheers for the replies
    How hard is it to get to the pump?
    Are we talking, wheel off - arch liner out.........?
    Scott.
    Mileage : 000
    Yes, you will have a lot more room if you remove the wheel arch liner.
    KENT
    mr-s - any luck? some photos would be good as I think I have the same problem!
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Leave the wheel on.. jack upthe car, wheel full lock to the right,remove teh 3 torx screws, pull the arch liner back,to gain access to the pump..remove the pump andclogged filter replace all done..simples.. no point getting to involved for a simple job.
  1. washer jets
    Last Post: 11th November 2011, 20:18
  2. Windscreen Washer Jets
    By John Bishop in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2010, 12:46
  3. Insignia windscreen washer jets
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2010, 19:00
  4. windscreen washer jets
    Last Post: 19th February 2010, 20:15
  5. washer jets
    By steve-wolves in forum Bodywork & Interior
    Last Post: 21st December 2009, 18:13
vectra c poor windscreen washers
corsa c weak wash jets
