Results 1 to 7 of 7
Thread: TC and ABS light staying on?
Hybrid View
    Nov 2009
    Bradford
    confused TC and ABS light staying on?
    I've just got home from work and after struggleing to get up a hill my TC & ABS light stayed on, when I got home turned car off and back on again and they still stayed lit, Will this sort its self out or is there a problem.
    Thanks for the help
    Jon
    Regular Member antowns's Avatar
    Nov 2009
    Amble, Northumberland / Ryton, Gateshead
    this happened to me the other day, all i did was find an open space with no ice and slammend on the brakes. I know this doesnt seem sensible but it did the job for me! hope this helps.
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    dont worry about it. all you need to do is drive normally and it goes away
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    it should just sort itself out next time you run the car
    Nov 2009
    Bradford
    Thanks everyone for the info, I was worried I'd broken something.
    Feb 2008
    Hertfordshire
    I found out after having TC and ABS lights on for a while I had an almost flat tyre. I am told that the car can indicate if one wheel is turning at a different speed due to a flat tyre and indicates it in the way you mention. Anyway - worth a check.
    Regular Member mattv6diesel's Avatar
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Year : 2008
    Quote Originally Posted by yozzaj View Post
    thats how the new corsa deflation detection system works with abs ring speeds so might be
  1. Oil light staying on
    By Jamesie82 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 22:31
  2. Spanner light staying on
    By WeDesign in forum Diesel Engine related
    Last Post: 7th March 2012, 16:41
  3. Indicatopr Light Staying On?????
    By lubo_tl in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2012, 21:27
  4. Help abs & traction light staying on.
    By Teza in forum Suspension, Wheels & Brakes
    Last Post: 14th December 2008, 17:09
  5. steering light staying on but all ok
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 22nd January 2008, 18:55
