Thread: Limp mode under acceleration - 3.0 CDTi
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Limp mode under acceleration - 3.0 CDTi
    English is not my mother tongue so bear with me if I get things wrong.
    My 3.0CDTi has very poor performance under 2000rpm and over 3500rpm. Lately the boost peak is happening at 2250rpm and pulls strong for about 1250rpm.
    I noticed a very odd thing the other day. The engine was running at a reasonable 1800rpm in 6th gear. I wanted to speed up a bit but knowing it has no power I changed down into 5th so it was just over 2000rpm. I held the revs for 10seconds or so, because there was someone flying by, then I floored it but the engine didn't flinch until the revs came up to 2500-3000.
    Earlier today it went into limp mode when I was overtaking a lorry. 6th gear @1900rpm.
    Diagnosed as Low boost pressure.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Lol your english may be better than mine
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Not what I wanted to hear, but thanks mate
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    is it a pre face lift as they suffer with sticking turbo veins causing under or overboosting
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    It's a 2003 Y30DT. Checked on Tech2 and the car is UNDERboosting. 0.2bar off.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Why the hell can't it just be a sensor. Can't be arsed to take the turbo off!
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    try a sensor first its just had a overboost fault on my y30dt where low revs and using the torque brings the light on. mine was over boosting. you can try cleaning/changing the sensor but sticky turbo's do seem a bit of a comon problem cause vx technical told me to fit it as been other cases
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I cleaned the boost sensor, to no avail. Spoke to Opel tech and he said it's probably a boost sensor problem.
    I'm used on spending money for repairs that another 115€ don't bother me much...If a new boost sensor won't help then another 350€ will fly out of the window
    But it's so annoying...always something wrong with it! Can't enjoy the beast and its true potential!
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    poor thing was lucky and my warranty covered it might be the distance drives you do made it last so long 40k miles mine died
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Either way...to the dealer tomorrow to place an order for a spanking new Hitachi Boost Sensor for Y30DT engine
  1. 3.0 V6 CDTi occasional limp mode...
    By fandango in forum Engine & Drivetrain
    Last Post: 21st June 2016, 13:24
  2. Cdti limp mode???.
    By steve1312 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2012, 00:46
  3. Please help?? 1.9 cdti 150 limp mode p1125
    By rsvphil in forum Engine & Drivetrain
    Last Post: 24th September 2010, 13:43
  4. Signum 1.9 CDTi limp mode
    By doublek500 in forum Engine & Drivetrain
    Last Post: 6th June 2010, 22:26
  5. 1.9 cdti 150 limp mode
    By jeets in forum Introduce yourself.
    Last Post: 30th May 2009, 20:29
3.0 cdti hesitant acceleration site:www.vectra-c.com
v6 cdti hestitant acceleration
what other turbo can i put in a 3.0 cdti vectra c
https:www.vectra-c.comforumshowthread.php98019-Limp-mode-under-acceleration-3-0-CDTi
3.0 cdti limp mode after hard
vauxhall vectra limp mode when accelerate
vectra low boost in sports mode
09 1.9 cdti vectra goes into limp mode when accelerating
what cause my insignia to go into limp mode when i accelerate
bt50 3.0 crdi in limp mode when accelerate
insignia goes into limp mode in sixth gear
acceleration limping
clean veins in turbo 1.9cdti
