Results 1 to 10 of 11
Thread: Boost 2.0 Sri
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Default Boost 2.0 Sri
    Can the cold weather make my 2.0 Sri not act as good? Ie I can't hear it boost like it normaly does, it still has a kick to it but not as good as it should do. I have the stage 1 BSR tune installed. I have only noticed the difference since it's been very cold. Cheers
    Regular Member Jezzy's Avatar
    S.E
    The extra boost from the remap won't kick in until the engine is thoroughly warmed up, and it could be as simple as the cold weather making the engine take a lot longer to reach the required temperature.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Mines performing even better...with the same set-up..
    Feb 2006
    North East Uk
    I can no longer hear the boost like I was, It sounded perfect when boosting, sounded great, it was strong all the time. It's gone since the cold weather. It still has power but no noise from the boost . I will give it a good run on the weekend and see how it goes. I thought it should be better when colder weather was here....
    Feb 2006
    North East Uk
    Infact it might be the standard dump valve I can't hear any more. I just no I can't hear the noise it used to make since it's been cold..
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    BSR remaps have a failsafe preventing you from getting full power until the engine is fully up to temperature. I haven't personally noticed any difference in performance in cold weather on my 2.0T.
    Feb 2006
    North East Uk
    Thats good to know. Mine still has power but I miss that noise it used to make. I will be out in it next on Xmas day, so I will see how it is then . Cheers
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Mines not standard,came with the car though,think its a 'forge'..but i dont really know tbh..TSSSSSSSHHHHHHHHHHHHHHHHHHH!!!!
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    The engine should (once warmed up) perform much better in cold weather.
    The colder the air into the intake, the better, hence why an intercooler is fitted. The intercooler will lower the intake temperature.
    Cold air is denser thus has more oxygen = better bang + noticeably better/smoother running !
    At high altitudes the turbo spins faster, but will still only give the same power due to less oxygen.
    Feb 2006
    North East Uk
    Well all is well, I heard the little noise I like the other day when I was out driving it . It's going in for a service next week, hope that won't cost to much
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
