Thread: Winter Trouble
    Jul 2009
    Oldham
    Default Winter Trouble
    OK. I cant get my car off our road , everyone else seems to be managing it fine.
    When i am trying to get up the road the clutch is fully out in first but I am being told that the wheels are still not spinning?
    Isnt there something wrong here...??
    Any Thoughts please
    FYI, this Vectra C has had a replacement engine(refitted poorly) and a replacement gearbox in the last 5 months
    If the clutch is fully out and the wheels are not spinning then you have big trouble and it won't go anywhere even if it wasn't icy! You will hear them spinning. Even with TC they will spin. I suggets its your efforts that are failing and not the car.
    Jul 2009
    Oldham
    whats the driveshaft for , people have mentioned to me it might be the driveshaft?
    Also everyday when i pull out clutch fastly there is like a knock under the hood somewhere. I jsut figured this was the loosly fitted air filter box?
    I think you need to speak to someone local who knows what to look for. The driveshaft goes from the gearbox to the wheel. If its missing where did it go? When did it pop out. This will be very very difficult to diagnose without seeing it.
    WGAF#5
    if the clutch pedal is fully out and the car is in gear i suspect you have burnt out the clutch plate as you have no drive - i take it the revs increase on attempting to pull away - maybe the "knock" on pulling out of junctions quickly was signs of clutch wear /warp
    do you have any burning smells when your trying to pull away (again clutch plate wear)???
    Jul 2009
    sussex
    could be a problem with the slave cylinder for the clutch, id like to assume a new clutch was fitted when the engine was put in?
    Jul 2009
    Oldham
    tried again this evening with a bit more effort and patience (made me late for work this morn) I managed to get up the hill. Car running fine so think the neighbour didnt know what he was talking about
    Thanks for the comments ppl much appreciated
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by Nojustice View Post
    Maybe the neighbour was staring at the rear wheels?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    was the gearstick in N
  1. Winter Kit
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2012, 13:14
  2. De-box for winter?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2010, 21:39
  3. Winter is nearly upon us!
    By Taffyopel in forum General Chat
    Last Post: 9th October 2008, 10:37
  4. An ode to Winter
    By AndrewTi in forum Comedy & Humour
    Last Post: 8th November 2006, 21:52
  5. Winter
    By CPHB in forum General Chat
    Last Post: 6th November 2006, 12:12
