Thread: Coolant Leak, Water Pump?
    Apr 2008
    High Wycombe
    Vehicle : Vauxhall Insignia
    Trim : SRI NAV
    Engine : 2.0 CDTI 140
    Mileage : 20000
    Default Coolant Leak, Water Pump?
    Hi all,
    Quick question. I've been loosing coolant over the past few weeks, not loads but enough for the light to come on once a couple weeks back.
    When I first start the car there seems to be a pumping noise coming from the left hand side of the engine, is it likely to be the water pump thats on its way out?? I cant see any water leaking around the coolant bottle or pipes, and there does seem to be some water on the under tray that side of the engine, but not sure if its just ice from the weather.
    Also if the water pumps replaced do you have to replace the cam-belt, not long had it done.
    Cheers.
    Mar 2007
    Tamworth
    Quote Originally Posted by rsocon View Post
    Once you've paid for, or done, the work to get access to the water pump then the cost of a new cambelt is peanuts.
    Northampton, UK
    I'm not sure what engine you have, but I had a major coolant leak a few months ago. It only did it when the engine was hot and it didnt do it all the time. I had all the pipes checked and then it turned out to be the water pump. Whilst they were at it, seeing as it's quite a job on the 2.0T, I had the belt Aux replaced.
    If your not loosing coolant when the engine cold, the water pumps a good place to try. When the engines hot, get someone to rev the engine and see if it starts to drip, or in my case poor out.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Water pump went on my last car (Clio) and when topping the coolant up with water, a puddle appeared underneath the car, in and straight back out! Maybe yours isn't as drastic but certainly sounds similair to what happened to mine!
    N.Ireland
    The water pump failed on my 19 cdti,it wasn't losing water though, ended up a disaster with a lot of damage done when the cambelt slipped,so if I was you I wouldn't even drive it.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as rob says get pump checked out asap if belt jumps you will want a fat wallet
  1. coolant leak
    By DavyB in forum Insignia car chat
    Last Post: 17th May 2012, 09:04
  2. V6 coolant leak
    By Critch in forum Engine & Drivetrain
    Last Post: 5th May 2011, 20:58
  3. Coolant Leak???
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 05:46
  4. 2.0T Coolant leak
    By mark1319 in forum Engine & Drivetrain
    Last Post: 19th December 2008, 22:53
  5. Water Pump/Coolant
    By barkzz in forum Engine & Drivetrain
    Last Post: 22nd September 2008, 22:31
insignia coolant leak
