Thread: new battery car wont start
    Jul 2009
    bolton
    Default new battery car wont start
    i had a new alternator and belt fitted 5 months ago and i was told that it might be best fitting a new battery in the near future.
    i didnt get a new battery because all was fine until lately when we have had freezing temps then i have had problems with the battery going flat if the car is left for 24/36hrs without being started.
    so 2 days ago i got a new battery and all has been fine until this morning when the car wouldnt start,everything is dead no lights,radio,central locking,dash lights, nothing works.
    has anyone any ideas what could be the problem
    Jul 2009
    bolton
    forgot to mention the cars an 03 2.2 elegance auto 80k
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    Sound like an alternator fault.
    first thing i would do is check the belt going to the alternator.
    also put a multi meter on the batt while the engine is running to see if there is any charge getting to the batt.
    HTH
    Regular Member poves's Avatar
    lancashire
    I know this sounds daft , but check the terminals .
    Quote Originally Posted by poves View Post
    first place to check imo ..............................
    Jul 2009
    bolton
    i put the old battery back on and everything worked, there wasnt enough power in the old battery to start the car but all electrics worked.
    so i am assuming i have some sort of electrical fault draining the battery,i have had the new alternator tested when the new battery was fitted just to make sure and all was fine,so its not faulty.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    or a duff battery ! you will need to get the new one charged up again then put a volt meter on it and see what it reads when running
    Irmscher Insignia CDTI 130
    Wales
    Charge up an check for voltage accross the the batt terminals with the car running (put a few 1000 RPM on her too) look for, from memory, about 13.5v - 14v. If youve got that voltage then its not the alternator.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Ontop of the 14v charge test, check the battery when dead. Technically you need to get a proper tester to see if the battery is okay, but a rule of thumb is that if the charge is below 5v it won't charge again! But does sound like your terminals could be loose or your alternators not working correctly.
    Oh and I forgot.. the alternator on most (if not all) modern cars should charge on idle If it only charges on high revs the belt may be slack/alternator internals faulty.
    Oct 2009
    Swindon
    Sounds like a duff battery.......Is it a Halfords branded one? seen a few of these playing up recently
  1. Wont Start!!
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th August 2012, 19:15
  2. battery drained and now wont start..ideas?
    By dahmich in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2012, 07:34
  3. car wont start
    By neill in forum Engine & Drivetrain
    Last Post: 16th January 2012, 23:00
  4. Wont start!
    By Dharm in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 20:10
  5. battery wont charge!!
    By manghan in forum Engine & Drivetrain
    Last Post: 28th March 2010, 11:48
