Results 1 to 10 of 23
Thread: Oil in Throttle Body 3.2v6
    Nov 2009
    W Mids
    Default Oil in Throttle Body 3.2v6
    I had the intake off my recently acquired GSI the other day and saw some oil in the Throttle body. It appears to be coming from the breather pipe how do I solve this? Should I be worried?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The breather pipe is just venting oil vapor from the cam covers, its normal mate. If its lost of oil then there might be a problem but just a little is fine.
    Nov 2009
    W Mids
    That was a fast reply!
    There was more than I expected (small pool freshly deposited) but I won't worry unless it gets worse.
    Thanks.
    Near Warrington
    dont worry about it unless its a large amount,regular oil changes keep these engines tip top
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by pigeon142 View Post
    As per my GSi, I'm guessing you're talking about the breather pipe that runs from the TB, along the front bottom cam cover, down the side of the engine and terminates down near the crankcase?
    Believe me, and I've yet to be successful, if the breather pipe hasn't ever been disconnected fronm the crankcase, you might find that removing it for a clean is a pig as the rubber hose, in my case, seems to have stuck solid to the crankcase spigot. There's little room to work in down below and I'm not able to prise the hose off. Mine's full of poo but regular cleaning of the TB does help.
    Nov 2009
    W Mids
    Decided to take my oil breather off to clean it but no matter how much I tried it would not come off. I noticed it had started to perish so ordered a new one.
    Ended up having to cut the old one off, you were not joking when you said you could not get it off!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Have you got a part no. and price mate?
    Having looked at mine again a couple of days ago and failed again to remove it, I'd agree with you that cutting it off is the only way forward.
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    So, the breather pipe to the TB is for crank case ventilation & not the cam covers?
    winsford
    i would be careful about cutting it off,i put a oil catch can on mine but i went to dealers to get a new pipe as i was going to modify it and you will find you cant buy one,guy pulled up parts list got no and not one had been sold and there aint any in stock either.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by AntB View Post
    Yes - on the 3.2 V6 if you trace it back from the front of the TB (it points horizontally towards the rad), it runs across the front cam covers and disappears down the back of the engine, between the gearbox and bulkhead, ie. top of the crankcase.
    I think I'll have to put a pic up to explain.
    As an aside, when I last checked my TB, there was an orange colored gunk in there. I can only think that this has come about because about 1500 miles ago when the engine oil was old (10k), I had a noisy tappet/valve. I added some Wynns or STP valve lifter stuff (didn't have time to change the oil) and the noise went away. I've since changed the oil (to 10W-40) and the valves still ain't tapping but still got this orange/rusty gunge. So do need to replace the breather.
  1. Now i think its the throttle body!! PLEASE HELP!
    By o9roberts in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2010, 16:06
  2. Where is the Throttle body on 2.2 dti?
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 14:29
  3. Oil on throttle body pcb
    By fattony in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 22:07
  4. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
  5. Throttle body
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2009, 20:27
vectra 3.2 oil catch tank screw removal
vectra 3.2 engine breather
vectra 3.2 v6 breather pipe symptoms
vectra c 3.2 throttle body coolant
vectra v6 throttle body breather hose
oil in throttle body
vectra 3.2 tappet noise
breather tube vectra 3.2 v6
