Results 1 to 10 of 29
Thread: spanner light
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default spanner light
    started the car today and all was fine went to the chippy and when i started the car the spanner light came on so i turned the car off and restarted engine again and all was fine, just finshed wor and started the car and the light came on again but went when i reved the car, is it the glowplug(s) and will the ecu still store the fault even tho the light aint on any more?
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    90 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Hi Chris, I've just moved this into a better section for you..
    Hopefully someone will be able to help you out
    Oct 2009
    Sandwell
    came on again today first thing when i started car but went out after i reved a few times any ideas?
    Regular Member P-Mutton2.2's Avatar
    Aug 2009
    Frinton on sea
    Probably due a service, If it goes out after 5 seconds or so
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Really need fault codes read,not sure how you can tell if its the Glow-plugs just from that
    Irmscher Insignia CDTI 130
    Quote Originally Posted by P-Mutton2.2 View Post
    The car/spanner light is not the service light. Been mentioned many many times before.
    Aug 2009
    Frinton on sea
    oops my bad,.. got a bit confused there , my car is doin it too now ha ha.
    gonna get glow plugs checked,
    Many similar threads if you search a bit.
    Oct 2009
    Swindon
    If it only comes on with a cold start and not when the engine is warm then it could indicate a glow plug fault, I had this so changed all 4 as a matter of course and all was well.
    Mar 2007
    Tamworth
    Should Vauxhall change the "spanner" warning light to a "get codes read" light?
    For nearly two decades, Vauxhall and other big manufacturers have been using systems which store fault codes and put a warning light on - there are just so many possible faults (1,000's) that the old idea of changing parts because it cured the undiagnosed problem on Fred's car is totally ridiculous.
    Aug 2009
    Frinton on sea
    Right,.. I have been to garage had fault code read for same (or similar) Problem.
    Fault read as low voltage to Glow Plugs. Hope that helps after my previous Error.
    By Shadrack in forum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
