Thread: surging engine on 2.0dti
    Apr 2009
    manchester
    Default surging engine on 2.0dti
    My 2.0dti 03 plate has been running rough today,seemed to be losing power/misfiring.When i stopped at lights the missfire was worse on tickover so held revs at 1000 and found it kept surging to 1500 and back.Been on internet and found it could be leak off pipes(changed 6mths ago),injector seals,egr fault,thermostat or fuel pump.
    Anyone any ideas or will a fault reader tell me anything useful even though spanner light hasn't been on.
    Get the feeling this is going to cost me.
    Apr 2009
    manchester
    Help
    newcastle
    Default diagnostics
    You are probably safer goin to someone with a diagnostics scanner as you will find that people on the forum will tell you everything that you have already read elsewhere and I dont mean any offence. You will get a code starting with PO and if whoever does your diagnotics cant tell you what the code is for type it into google. But someone with a good code reader should be able to tell you straight away what it is. Fingers crossed it aint your fuel pump
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    i had a vec B 2.0 DTI before my C and had same prob - it was the airflow meter in the end
    newcastle
    could be that. i have been told by my mechanic that if the air fow meter is gone there is not that same crisp noise at 1800 revs. if you know what i mean.
  1. Engine Problems 2.0DTi Y20DTH
    By Daniel89 in forum Engine & Drivetrain
    Last Post: 16th August 2011, 19:10
  2. 'Spanner' engine management light on 2.0Dti
    By Bigdrinks in forum Engine & Drivetrain
    Last Post: 14th May 2011, 12:50
  3. Engine Replacment on 2.0DTI
    By ectraz in forum Engine & Drivetrain
    Last Post: 28th December 2009, 14:19
  4. Engine management light - veccy b (2.0DTi)
    By Led in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2009, 17:10
  5. Engine Remap on 2.0DTI Siggy
    By Mad_Matt in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2007, 21:14
2.0 dti surging
