Thread: Fixed my car.. So proud
    Regular Member petel's Avatar
    Nov 2007
    bristol
    Default Fixed my car.. So proud
    Over the last couple of days my Vec has been playing up.
    First fault was the cooling fan running costantly even when stone cold.
    Then it started to misfire when under load (1.8vvti) so i booked it in to the local dealer for today.
    Yesterday i was having a nose under the bonnet when i noticed the loom for the air flow meter had come loose from the clips securing to the air box and was rubbing on the pulley and in fact had cut through one wire and marked the other two
    So some solder and wire later a complete repair and all problems solved
    If i had put the loom clips back in properly after cleaning the K&N it would probably never have happened
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Well done mate, glad you sorted it, although it appears it was your fault anyway. !
    Nov 2007
    bristol
    yep 100% guilty,glad I found it tho and not the dealer SWMBO would not have been happy
    Regular Member Readster's Avatar
    Plymouth
    Job done Petel, and good advice for the rest of us too
  1. Proud old man
    By colail in forum Introduce yourself.
    Last Post: 21st December 2011, 20:21
  2. OMG I'm so proud of myself
    By lizard in forum General Chat
    Last Post: 15th June 2011, 12:36
  3. proud dad
    By aledjones_lex in forum General Chat
    Last Post: 13th June 2010, 19:28
  4. Proud Dad!
    By Caterman in forum General Chat
    Last Post: 24th August 2007, 20:19
  5. I'm a proud dad.
    By Stevel in forum General Chat
    Last Post: 24th April 2007, 00:06
