Results 1 to 10 of 13
Thread: Outside temperature sensor gone mad!
    Ireland
    Default Outside temperature sensor gone mad!
    Hi folks,
    The outside temperature on the display of my Vectra C is gone nuts in recent months. At the moment i'm getting readings of minus 30 to 40 and during the summer I was getting plus 30 when it was barely 17 or 18 outside! Any ideas on this - is it just a case of replacing the sensor or is there calibration involved? The sensors appear to be less than a tenner on ebay...
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Is that not just UK weather ..... IIRC the sensor doesn't need calibrating etc just replaced...
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    Got to be a faulty sensor. For the cash i would buy one and try it, only a 5 min job.
    Ireland
    OK cool - will go ahead and get one.
    Now for the next question - anyone know how to change one?!
    hull
    unplugged mine, cleaned the terminals bit of wd40. perfect since.
    easy change, just in front of radiator lower middle 1 plug (sri location).
    Ireland
    Will give it a go - thanks for all the help!
    Mar 2007
    dunstable
    Hi,
    can someone tell me where the sensor is fitted on a signum.
    Cheers.
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Quote Originally Posted by leeashford View Post
    Hi,
    Cheers.
    Quote Originally Posted by frasedeb View Post
    Regular Member billyyoung's Avatar
    dundee
    mines done the same , it was the big multi plug connecting to the sensor loom . the terminals had corroded , I just cut the plug out and wired them straight through
    Solihull
    Hi everyone
    my temp sensor always reading around 8 deg C less than actual outside temp. I'm having difficulty finding it. Can someone please write step by step instructions? I have a 2006 SRI 1.9 cdti, the one with the newer more modern looking headlights.
    i don't know what/how to remove things to get to the sensor?
    thanks
  1. Outside Temperature Sensor
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2009, 23:35
  2. Outside air temperature sensor
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 13:31
  3. Outside Temperature Sensor
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2008, 10:59
  4. outside temperature sensor
    By billyyoung in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 17:23
  5. Outside Temperature Sensor U/s
    By turnerk in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2007, 22:05
