Results 1 to 10 of 11
Thread: Breather pipes
    N.Ireland
    Default Breather pipes
    Can anybody make any sense of what the mechanic has done at the stealers,below the EGR you can see a u shape pipe and below that a box with pipes that have been cut.I know that there used to be pipes coming from the box up to where the u shape is.hope I,m making sense,
    norn iron
    is that a piece of twig jammed in below the valve????????
    N.Ireland
    Yeah the clip is a bit loose in the EGR valve,afraid of it slipping off
    N.Ireland
    Quote Originally Posted by deg View Post
    I thought I was gonna get a bit of help when you showed interest.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Best thing for some one to do is take a picture of their engine bay around the same area as your's then compare,so if anyone wants to brave the weather and take a picture
    I take it yours is a 19 CDTI SRI
    Irmscher Insignia CDTI 130
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    i've found these pictures on the forum Vectra CDTi Posted by keithsimmo
    Thread is here click me
    hope it helps
    N.Ireland
    Thanks for the help lads,the car is a 19 cdti...I got some work done a while back and at the time had noticed a pipe of at the back of the Manifold,I know there was two pipes leading up from the breather tank (I think its called),so I brought it over to the stealers and pointed this out and he said yeah that would have gave the same code as the EGR valve,so this is the way they left it,there could be no harm done but they seem to be bypassing the breather tank completly why ???..cheers
    N.Ireland
    I was reading on another thread about two pipes being changed on the vacuum box leading to the actuator,is this a vacuum box I was trying to find info about,anybody any recent pics of this same area,are does any one know why this was done.cheers
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Hi the vacuum box is at the front right of the engine bay on your front bumper look at the sticky thread at top of this section shows vacuum pipes and box
    the thick rubber pipes next to
    your egr are the oil breather pipes from your crank case and cam shad breather that goes into your oil seperator which is the black round container with about 4 pipes going into at the back left of your engine
    and you can vent your breather system to atmosphere with
    no probs and no fault codes look at my thread in here for diy oil catch tank for pics
    That u bend pipe I have no
    idea of sorry
    Hope this helps
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    [quote=rob123;1124056]Can anybody make any sense of what the mechanic has done at the stealers,below the EGR you can see a u shape pipe and below that a box with pipes that have been cut.I know that there used to be pipes coming from the box up to where the u shape is.hope I,m making sense,[/quot
    you are talking about the vacum box just below the 'u' pipe shown in the pic!, the pipes go to a valve mounted on the right by the radiator, dont know why they have done this ?.
  1. Breather filter
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2015, 20:14
  2. 3.2 Oil Breather Help
    By gibsonk in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 01:52
  3. oil breather
    By Matt&Jemz in forum Petrol Engine related
    Last Post: 31st July 2010, 14:38
  4. oil breather
    By Dougb in forum Engine & Drivetrain
    Last Post: 8th May 2010, 18:10
  5. breather filter?
    By mickyblueyees in forum Diesel Engine related
    Last Post: 8th May 2010, 15:34
1.9 cdti crankcase breather
z19dth boost leak test
astra 1.9 cdti oil breather
1.9 cdti oil catch
1.9 cdti breather
vectra c breather pipe
vauxhall insignia crankshaft breather pipe
vectra c sri 150 pipe next to egr
vectra c sri crank breathers
vauxhall vectra breather system www.vectra-c.com
opel 19cdti oil catch tank forum
vectra c cdti crankcase breather system
vectra c cdti crank breather pipe
vectra c crankcase breather
https:www.vectra-c.comforumshowthread.php97906-Breather-pipes
vectra c 1.9 cdti agr filter
oil breather system for vauxhall vectra
